Table legs and table mounts
lozcruisin
#1 Post by lozcruisin » Tue Aug 25, 2015 9:40 am
Hey All,
Those of you that know Pontoon tables and legs and bases sizes please pipe in. I have a round table with the wrong leg on it. My base is a flush 2-1/4" taper and my table has a straight aluminum legs permanently attached to the table base. It has 6 screws attaching the mount to the table. It is wobbly and the PO shot screws into the leg at the base to take up the slack from not being tapered. I would like to keep the table and the flush 2-1/4" base. I found a tapered leg and tapered table base and am wondering if the 6 screw bases are all the same spacing for the table base. Here is the table base and floor base I want to use: http://www.pontoonstuff.com/collections ... -table-leg Here is the table base:http://www.pontoonstuff.com/collections ... able-mount I hope this explains it well enough? Thanks.
Regards,
Ken
Re: Table legs and table mounts
#2 Post by curtiscapk » Tue Aug 25, 2015 9:54 am
I am pretty sure they are all the same. Can you take a picture of the base on the table and compare it? I know I can interchange my old table top and use it with my new leg after the rebuild.
lozcruisin
#3 Post by lozcruisin » Tue Aug 25, 2015 2:41 pm
Craig,
Thanks for the info. I assumed they were likely interchangeable but was not sure. I will take a picture and compare.....
Regards,
Ken
Friz
#4 Post by Friz » Tue Aug 25, 2015 7:19 pm
I believe the diameter is actually 2 3/8 O.D. and it is (was) made by Springfield. They no longer make them. I have been looking for the same one and frankly, not much luck. I started with the least expensive and worked my way up. Everyone said "out of stock" I found one supplier who said he had one for around $60. I said "no thank you".
So, just took a quick look to find the Springfield p/n and wouldn't you know it. I found one looking very similar on Amazon for $15.99! The length is right, 28 1/2" and the ends are tapered but they don't state the diameter. It may not be 2 3/8" as they also try to sell you the round flush table base. Unfortunately if it doesn't fit your current base it also will not fit your table. May be worth looking into though as I have had a heck of a time finding one for the front table.
#5 Post by curtiscapk » Mon Aug 31, 2015 7:08 pm
Ken,
We actually made it to the lake and got THE FLOATER in the water for the first time all year. I took some pics for you. My toon is a 94 Party Barge the original table leg fit in my new base from pontoonstuff. I forgot to take a picture of the new leg but of course it fits as well. The table tops in the picture are the original rectangle one and the new round one from PS. Both legs fit in either table top. Sorry for big pics.....
Let me know if you have any other questions.
lozcruisin
#6 Post by lozcruisin » Tue Sep 01, 2015 6:00 am
Craig,
Thanks. I ordered the Sur-fit leg and table base along with two new flush floor bases from Pontoon Stuff and they will all fir perfectly. Thanks for everyone's input.....
Regards,
Ken
#7 Post by curtiscapk » Tue Sep 01, 2015 6:53 am
Sweet! did you use the discount code?
lozcruisin
#8 Post by lozcruisin » Wed Sep 02, 2015 10:45 am
Craig,
I didn't see a coupon on the site? Where did you see it?
Regards,
Ken
#9 Post by curtiscapk » Wed Sep 02, 2015 11:19 am
top right on this site! forum10 is the code.
IF you call them they will discount your card.
lozcruisin
#10 Post by lozcruisin » Thu Sep 03, 2015 5:38 am
Dah......For sure next time.
Regards,
Ken
