Looking at buying a trailer for my tritoon
flossy2150
I have a tritoon (see sig for the details) and I did not buy a trailer with the boat because the plan was to keep it on the lift and I would only have to pull it out for storage in the off season. I'm in VA where it snows a bit and I really don't want the boat outside if I can help it so I need to buy a trailer to store it in the off season. I am going with the bunk style trailer with 3 bunks.
The boat is 2,100 lb, motor is 466 and 60 gal fuel tank adds about 400 lb - so total weight will be pushing 3,000 lb. I sent emails to various trailer/marine dealers this week and got several quotes. Here are the details for each...
1.) Venture (Vantage Custom Line) -- 4000# $3952.00
2.) Road King (Aluminum Tandem Pontoon Trailer) -- 4450# $3600.00
3.) Load Rite (24T4100102HTRIB1 galvanized and adjustable center bunks) -- 4100# $3,964
4.) PMI Marine sent me two quotes...
Flote-On Pontoon Trailer
Tandem Axle, Four 13" Tires, 4500 lbs
Capacity. 18' Bunks, 28' Overall
Length, Dual Wheel Tongue Jack
Heavy Duty Trailer w/ no brakes -- $2265 + $299 bunk kit = $2564.00
Same trailer with brakes -- $2755 + $299 bunk kit = $3054.00
The first 3 quotes are all from local dealers. The 4th is from a manufacturer that sells direct in Indiana. I am in VA but could conceivably make a road trip to go and pick it up.
My questions --
Who else would you try to get quotes from? Any gotchas I need to look out for?
My questions --
2015 Sylvan Mirage Cruise 8522 LES RPT PR25 Package
Outboard: Yamaha F150XA
Prop: Solas "New Saturn" 3531-145-15 (Stainless Steel, 3 blade, 14.5" diameter, 15" pitch)
Re: Looking at buying a trailer for my tritoon
With a total weight of over 3000 lbs, trailer and load, you must have trailer brakes in Va and most other states.
'03 F250 Powerstroke
crookedlaker
I bought a center lift trailer from PMI
www.trailersforpontoons.com check out their web site for a lot of info on choosing the correct trailer
Great people to deal with, even came in on Saturday so i could pick up my trailer without having to take time off work.
I would highly recommend them.
good luck
good luck
2017 Harris Sunliner 200
Tri-toon P+ Package
2017 Mercury 150 4 stroke
Tri-toon P+ Package
I agree. I have one of Paul's Mid-America triple bunk type trailers for my Bennington and they've been a pleasure to deal with all along the way.crookedlaker wrote:I bought a center lift trailer from PMI
http://www.trailersforpontoons.com check out their web site for a lot of info on choosing the correct trailer
good luck
Does that pontoontrailers.com place deliver. Not looking to buy at this moment, but you never know...
2014 Sweetwater 2086SW
90 Hp Yamaha 4-stroke
crookedlaker
They will deliver using contracted drivers,
Most customers pick up at their location
You can also pick up in MO if that is closer
Mike
Mike
Tri-toon P+ Package
Tri-toon P+ Package
Even if it is not required by law in your state, I would highly recommend getting brakes on whatever trailer you get.
2010 150 HP Mercury Optimax
flossy2150
Ray Jr. wrote:Even if it is not required by law in your state, I would highly recommend getting brakes on whatever trailer you get.
I agree. It is required by law in my state (VA) for anything over 3,000# gross weight. I got a little more info on the Venture trailer...
Venture Model #VPT26-40 TRL
galvanized steel frame
tandem axle w/ 20.5x8x10 wheels
surge type brake system
Just e mailed them my order sheet.tms0425 wrote:I agree. I have one of Paul's Mid-America triple bunk type trailers for my Bennington and they've been a pleasure to deal with all along the way.crookedlaker wrote:I bought a center lift trailer from PMI
good luck
2015 90 HP Yamaha
2017 4WD GMC Canyon
2015 90 HP Yamaha
2017 4WD GMC Canyon
