Tool Guide For The Shop...
SKIL SAW:
A portable cutting tool used to make boards too short.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing projects.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench at the speed of light. Also removes fingerprints and hard earned calluses. Will easily wind a tee shirt off your back.
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal objects out of your hands and throwing them across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
CHANNEL LOCKS:
Used to partially round off bolt heads. Sometimes used in the creation of blood-blisters.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after Channel Locks to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for igniting various flammable objects in your shop and creating fire. Also handy for igniting grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity. Very effective for digit removal.
HYDRAULIC FLOOR JACK:
Used to raise a vehicle almost high enough for the required task.
BAND SAW:
A large stationary power saw primarily used by most shops to cut large pieces into smaller pieces that more easily fit into the trash can. Also excels at amputations.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of all the crap you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removeable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
PVC PIPE CUTTER:
A tool used to make plastic pipe too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object you are trying to hit. Also very effective at delayed fingernail removal.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door. Works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. These can also be used to initiate a trip to the emergency room so a doctor can stitch up the damage.
BELT SANDER:
WIRE WHEEL:
DRILL PRESS:
CHANNEL LOCKS:
HACKSAW:
VISE-GRIPS:
OXYACETYLENE TORCH:
TABLE SAW:
BAND SAW:
PRY BAR:
PVC PIPE CUTTER:
HAMMER:
UTILITY KNIFE:
2010 Sun Tracker 21' Fishin' Barge 90hp Optimax
2003 Chevrolet Silverado Z71
2000 Georgie Boy Cruise Master
Acts 16:31 (KJV)
Acts 16:31 (KJV)
Re: Tool Guide For The Shop...
HIGH SPEED BUFFER:
For wrapping up power and extension cords tight as tight can get. (been there, done that)
Good List! Lets keep it going!
Chainsaw - used to open up large gaping wounds on previously un damaged human legs
Fishing baits with treble hooks - guarantees cap removal of fishing partner or ear piercing of same unlucky partner.
Cresent wrench or adjustable wrench - used to round off bolt heads or at least taking skin of knuckles. Also handy for throwing at lawnmower with rounded bolt heads.
Gonefishing
Edge planer
Used to shorten long fingers
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
2013 115 Yamaha
Belt sander, Becomes race sander after coming unplugged while in constant on position and re plugged
- NonHyphenAmerican
Wrench: Barks knuckles, breaks bolts or studs off requiring them to be drilled out and re-tapped. Also winds up lodged in windshields requiring a vist from NOVUS to replace the damaged windshield.
Don't ask how I know the last part.
Inquiring minds are wondering....NonHyphenAmerican wrote:Don't ask how I know the last part.
I must be missing something...
MINI-FRIDGE (Stocked with appropriate beverages)
trucky wrote:I must be missing something...
And there in lies the problem!
- NonHyphenAmerican
Picture this:Bryden24shp wrote:Inquiring minds are wondering....NonHyphenAmerican wrote:Don't ask how I know the last part.
Working on brakes and axle on 40+ year old Bronco.
Things're not going together like they should.
Wrench slips and the wrencher receives a gash across the knucles.
With a hearty "Sonuvab*****"
Interestingly enough, windshields on nearby vehicles do not stand up to thrown wrenches.
Honestly didn't think it'd go as far as it did when I chucked it.
Flashlight. A hollow metal or plastic tube used for storing dead batteries.
Tim
Tim
