Motor dies when put into gear
b52thomas
#1 Post by b52thomas » Tue Oct 06, 2015 7:34 am
My son took out my pontoon and over oiled the gas mixture. I've since corrected all mixtures and have run cleaner through it twice. My issue is that it starts fine and with the idle up but when I lower the idle and put it in gear, it dies. Eventually it will run when in gear but will be difficult to start. Checked fuel filter and it appeared to be full of gunk(for lack of a better term) and I've replaced it. I haven't had it back in the water since then so I'm not sure if that might help the situation. It's a 1988 90hp Merc 2 cycle. Any help/advice would be welcome.
Thanks,
Bill
Seon
Re: Motor dies when put into gear
#2 Post by Seon » Tue Oct 06, 2015 8:08 am
If you haven't yet, you might want to check the spark plugs that maybe fouled.
1989 28' Tracker Party Hut
115 hp 4 stroke Yamaha
Sacramento, Ca
teecro
#3 Post by teecro » Tue Oct 06, 2015 8:17 am
Seon wrote:If you haven't yet, you might want to check the spark plugs that maybe fouled.
Yep... I'd start with a NEW set of spark plugs and see where your at....
#4 Post by curtiscapk » Tue Oct 06, 2015 12:47 pm
Clean plugs, clean Fuel Filter = good to go. :thumbsup
b52thomas
#5 Post by b52thomas » Tue Oct 06, 2015 2:22 pm
Thanks for the replies guys... I'll definitely try that...
b52thomas
#6 Post by b52thomas » Thu Oct 15, 2015 12:29 pm
Just as a follow-up.... did as suggested....replaced fuel filter and plugs.... runs like a striped ass monkey... thanks guys... Bill
#7 Post by RcgTexas » Thu Oct 15, 2015 1:02 pm
Assuming that's a good thing! :biggrin2 :thumbsup
