Mad4sax
#1
Post
by Mad4sax » Wed Mar 09, 2016 8:24 am
I did a search on the forum and only found the grill made from a toilet.
Does anyone have a grill and if so what brand. Or grill rail mount brackets??
Thanks.
Gonefishing
#2
Post
by Gonefishing » Wed Mar 09, 2016 9:04 am
This is what I purchased. I used the sam pedestal used on my table to mount the grill on the rear platform of the boat
- image.png (1.49 MiB) Viewed 5719 times
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
TDJ2591
#3
Post
by TDJ2591 » Wed Mar 09, 2016 6:48 pm
Mad4sax wrote:I did a search on the forum and only found the grill made from a toilet.
Thanks.
Try searching the forum again. I found 60 pages of discussion threads when I searched for "grills". Read the comments and the discussion topics, then open the threads. There are lots of discussions about grill brands and grill mountings along with lots of photos. Start with the discussion "What have you added to your pontoon" (I believe that's the name of the discussion) then open some of the other discussions. Good luck! You'll find tons of info on the forum.
LittleRiver
Post
by LittleRiver » Sun Mar 13, 2016 5:25 am
Little effort, but its easy to convert a home grill to a boat grill.
Have a bass boat and I've use the gas pedestals on seats before.
Use L brackets to secure the tables on the sides, so they are fixed and secure. Grill raises itself when you push the black levers down, to cookout height then you push the levers down, little pressure on the grill it goes back down where you can see fine over it.
Bottle is behind the captains seat run a line down the side so bottle and fire are a long way from each other. Grill is a IR so there is no flair up on fires.
[URL=http://s298.photobucket.com/user/liveab ... 2.jpg.html]
http://i298.photobucket.com/albums/mm27 ... a1caec.jpg[/IMG][/URL]
[i][color=#0000BF] ...08 24' Party Barge "Tiggers Toy" 50hp..[/color][/i]
[i][color=#0000BF] ..Triton TR21X 250 V-Max "Yellow Bullet".. [/color][/i]
[i][color=#0000BF] .. Little River Motorsports Top Dragster T/D[/color][/i]
[i][color=#0000BF] ..Dodge and Ford truck, but still race a Chevy[/color][/i]
Capt Sully
#5
Post
by Capt Sully » Sun Mar 13, 2016 12:20 pm
I move mine around the toon using a rod holder mount. In the rear when running the boat and on the side or front when cooking.
- BBQ Grill.jpg (118.24 KiB) Viewed 5326 times
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
#6
Post
by Bamaman » Sun Mar 13, 2016 5:37 pm
I would want any grill to stay away from my upholstery.
I got my home gas grill too close to my house, and it melted the vinyl siding on the fireplace chase. I've got to replace the siding before I can put the house on the market.
Coldbrew
#7
Post
by Coldbrew » Mon Mar 14, 2016 11:21 am
I've got a Kuuma mounted over the water. I just had to turn the screws in from the back because my fence goes all the way up to the rail. It works great. I leave it on all season. Picked up a cover for a Weber table top grill for 10 bucks at Lowes that fits perfectly.
2014 Premier Gemini 201
Tow Vehicle: 2019 F-150
Home Port: Newfound Lake, NH
HarryO
#8
Post
by HarryO » Mon Mar 14, 2016 4:41 pm
I have been researching grills for my pontoon. Although I haven't purchased yet I've made some inroads as to what I want in a grill. I'll try and list them in order of importance :
1. All stainless including the grill. (ease of cleaning)
2. Two burner and a total of at least 20,000 btus (good sear on steaks and burgers, wide temp range for cooking)
3. Locking cover tall enough for cooking different foods.
4. Able to use 20lb propane bottles.
5. Able to be rail mounted and removed easily.
6. Less than $150.00. (I'm frugal)
Both Lowes and Home Depot have portable grills that fit the above criteria for less than $150.00. Hope this helps you answer some questions about grills.
Crusing on the Delaware River and fishing the Delaware Bay
2006 King Viper 2160
Suzuki 225DF
2001 Weeres Sportsman 20
Evinrude 50hp 2 stroke
Mosnowman
#9
Post
by Mosnowman » Thu Mar 17, 2016 7:32 pm
I use a Magma....love it!
BUSY LIVING...
Columbia Mo BZLIVN
NonHyphenAmerican
#10
Post
by NonHyphenAmerican » Thu Mar 17, 2016 8:47 pm
I have one of these.
Works on the toon, works for a quick picnic, works for just about anything where I need to be able to move a grill quick and easy.
Made by Coleman and available lots of places. I bought mine at Menards.
I also have a "Grill Mat" which is a fireproof/heatproof rug to protect the vinyl flooring.
Mad4sax
#11
Post
by Mad4sax » Fri Mar 18, 2016 6:35 am
NonHyphenAmerican wrote:I have one of these.
I have the old version of that grill. I was thinking of trying to rail mount it. Maybe a Grill Mat under it and just setting it up might work. Thanks!
