Palazzoblues
#1
Post
by Palazzoblues » Tue Apr 05, 2016 5:25 pm
Just wondering if anyone uses one of these Trailer jacks?
https://www.trailervalet.com/
I could sure use one to get my pontoon boat on a tandem axle trailer in a tight spot close to my garage wall. I thought I would be able to man handle that thing into place like I did with my smaller single axle trailer, but the tandems twist and it wants to go right back to the same spot I pushed it from. It is not feasible for me to back it into position as I'd hate to hit the wall or worse yet the motor in the back.
teecro
#2
Post
by teecro » Tue Apr 05, 2016 6:02 pm
How about them real low wheeled platforms you put under the wheels of a car? A little time and labor but then you could back in garage, place platforms under the wheels and then push right up against the wall till its 1" off....
teecro
#4
Post
by teecro » Tue Apr 05, 2016 6:28 pm
^^^ Yeah what he said... ^^^
Palazzoblues
#5
Post
by Palazzoblues » Wed Apr 06, 2016 5:56 am
Never thought about those. But 4 of the $100 ones will cost more than the Trailer Valet. I wouldn't consider the other cheaper dollies.
robertm
#6
Post
by robertm » Wed Apr 06, 2016 9:51 am
Have a neighbor with a similar situation to you. He bought one for his boat and seems to do real well with it. His boat is 18 ft V haul but weight as long as you are within the specs of the product it should work out well for ya. I know it allows him to be very precise.
'Miss Kelley'
Yamaha F200 LB
14.5" X 15P SS Reliance
2015 Ram 1500 Eco Diesel
Reiner
#7
Post
by Reiner » Wed Apr 06, 2016 10:21 am
Palazzoblues wrote:Never thought about those. But 4 of the $100 ones will cost more than the Trailer Valet. I wouldn't consider the other cheaper dollies.
I think you only need (2) Once it is up on both sides it will act like a single axle trailer and not twist back.
2011 Tundra
Palazzoblues
#8
Post
by Palazzoblues » Wed Apr 06, 2016 3:43 pm
Good point, can anyone confirm if those harbor freight dollies (the nicer ones with the foot lift) would actually pick up one axle high enough to lift the other wheels of the ground?
RonKMiller
#9
Post
by RonKMiller » Wed Apr 06, 2016 5:51 pm
Why not just use a floor jack to lift the trailer off the ground and slip two dollies under the wheels?
Don't forget 20% off coupons at Harbor Freight are everywhere. At the current price it would be $48.00 to move your trailer over...
RonKMiller
#10
Post
by RonKMiller » Wed Apr 06, 2016 5:55 pm
I agree, BUT, it's not like you're going to be moving it back and forth all the time. My bet is they will survive the short roll on smooth concrete.
"Constructed of sturdy steel, these car dollies are designed to withstand the weight of your car for easy maneuverability. Each car dolly individually can hold up to 1500 lb."
Worst case scenario you have to go back through the line with another 20% discount coupon and you've increased the load to 3 tons for under a C note.
#11
Post
by ROLAND » Thu Apr 07, 2016 2:43 am
I bought this trailer dolly early last season... best purchase I've made in a long time.. makes it soooo easy to maneuver my boat into tight spaces... not cheap, I think it was around 189.00 or close to it, but this thing really makes moving the boat almost effortless..... I highly recommend this dolly.
- 24383_700x700.jpg (64.78 KiB) Viewed 6147 times
Post
by Bryden24shp » Thu Apr 07, 2016 5:51 pm
I just got done moving my old Premier to the other side of the boat shop to make room for the Manitou, tomorrow. I used 4 dollies under the tires and a floor jack to move it. I sold the Premier last night, (YEAH) but her new owner can't pick it up for a few weeks, so I'm storing her for him. Will be cool to see the new boat next to her tomorrow night!
- 20160407_191043.jpg (117.76 KiB) Viewed 6034 times
- 20160407_191058.jpg (82.3 KiB) Viewed 6033 times
- 20160407_191118.jpg (125.46 KiB) Viewed 6033 times
Post
by Bryden24shp » Thu Apr 07, 2016 5:54 pm
Reiner wrote:Palazzoblues wrote:Never thought about those. But 4 of the $100 ones will cost more than the Trailer Valet. I wouldn't consider the other cheaper dollies.
Nope, you have to support all 4.... I just found out the hard way..... Those leaf springs do flex alot!
HarryO
#14
Post
by HarryO » Sat Apr 09, 2016 8:39 pm
The best investment I ever made for parking a trailer anywhere was a front hitch on my pickup. 80 bucks installed and I can put either of my boats anywhere I want. Short of a 90 degree turn just about anything else can be achieved.
I added a short cord and connector to deactivate the trailer brakes while backing up and lighting the running lights on the trailer. The beauty of this setup is that you can see where your going.
Gotta admit that the truck does get some strange looks when I'm at WAWA for coffee.
Crusing on the Delaware River and fishing the Delaware Bay
2006 King Viper 2160
Suzuki 225DF
2001 Weeres Sportsman 20
Evinrude 50hp 2 stroke
