"May" have some water in one or both of my logs. Sounds like it is flowing when I drop the nose of the trailer. OR, it could be I am hearing fuel in the tank move. How do I check IF there is water in either of those suckers? There is a top port in both nosecones and a port in both logs just behind the nosecones. Not much area to work in.....looking for advice!!
Thanks,
Sami
Water in 'toon??? Advice please !!!
2013 Sweetwater 2286 Yamaha F115LA
- killerkernrich
Re: Water in 'toon??? Advice please !!!
I had 60 gallons in one of mine SHAKE it real good when on trailer you will hear it
PLP Member
NRA member
UFC fan
PLP Member
NRA member
UFC fan
Pontoon Pirate
All of the pontoons that I have owned have had drain plus at the bottom rear of each pontoon, does yours?
Being a 2013 I would think it would have the plugs referred to above. Last year I thought I had water as well, turned out, just the fuel sloshing around. I think you'll find the same. Hopefully.
