I recently purchased a fish finder for the toon. I am going to mount it on the console so I will need to drill a hole or two to run the cables for power and the transducer. What would be the best way to seal the hole(s) to keep water out? Has anyone used the cable clams from Blue Sea or the Scanstrut deck seals?
Thanks
Running cables through console
2015 Avalon LSZ 2085
Re: Running cables through console
find some gromets
On my Humminbird the cables went down through the unit mount. It was sealed by the mount itself.
As far as running the cables through the deck, I used the same hole that all the other cables (power, lights, steering) went through. It was sealed by expanding foam, so I just dug enough of the existing foam out to push the cables through and then resealed with more foam.
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
2016 Chevy Tahoe
2009 GMC Sierra
I use duct seal compound for that sort of thing
AKA Monkey Shit.MH Hawker wrote:I use duct seal compound for that sort of thing
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2016 Chevy Tahoe
2009 GMC Sierra
