DIY glove boxes?
Joseph Elliott
DIY glove boxes?
The space I have available on my console doesn't allow for a normal size glove box. Does anyone have any experience making their own?
Alberta, Canada
Home made 16' pontoon, 1980 60HP Johnson- work in progress
Re: DIY glove boxes?
What about a "dry box" instead of trying to make anything? If you want it permanent then mount it somewhere.
http://www.overtons.com/modperl/product ... aQodmuQHMA
Joseph Elliott
Because the hole already exists
Alberta, Canada
Didn't know the hole was already there
What about a glove box insert. For example (some with doors and some without):
http://www.jcwhitney.com/omix-glove-box ... 63876.jcwx
http://www.thejeephut.com/products/omix ... odels.html
http://www.quadratec.com/products/91331 ... oCXS_w_wcB
http://www.walmart.com/ip/32189144?wmls ... 52&veh=sem
Joseph Elliott
I need something smaller, 8.5" wide, 4" high, 12" deep.
Alberta, Canada
I found and bought this one pre-made online, bought it and installed myself. They say measure 3 times and cut once, pretty sure I measured that hole 7 times before I made a cut. Turned out great especially since I didn't have a glove box before this one. Anyway, the box I'm sure is home made (or professionally made) just by using that plastic sheet material (can't think of the name right now) that you see used for many things on boats. I'm sure you could use the same concept to make whatever size you need. If you need I could take more close up pictures but it would be a couple weeks until we're back at our boat, just let me know.
- xxxx (360x480).jpg (63.67 KiB) Viewed 4469 times
- xxx (360x480).jpg (62.86 KiB) Viewed 4469 times
- xx (360x480).jpg (53.04 KiB) Viewed 4469 times
- x (300x400).jpg (43.02 KiB) Viewed 4469 times
115 hp Merc 4-str.
Collinsville, IL.
Boat on Ky Lake
115 hp Merc 4-str.
Collinsville, IL.
Boat on Ky Lake
Walter,
Where online did you find that one? It is much nicer than the one that came standard on out 2007 Bennington.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Lake Conroe, Texas
2006 Yamaha F225
I've seen similar at www.greatlakesskipper.comDrago wrote:Walter,
I do think it may have came from that great lakes skipper place. I'll have to do some looking and digging to see for sure, I just looked at their website, and they've got alot more options now. I don't think I paid more than $50 or $60 for it. A guy could easily make one out of that starboard material and some stainless hardware but for about $60 I don't think your going to come out saving too much after buying the materials.
115 hp Merc 4-str.
Collinsville, IL.
Boat on Ky Lake
115 hp Merc 4-str.
Collinsville, IL.
Boat on Ky Lake
Paul
Joseph Elliott
Thanks for the responses guys
In the end I built my own out of pvc sheet and wood.
Alberta, Canada
