Do not know anything about batteries. If you have two batteries and you want to put them together, can you just . Run a cable from positive post of one battery to the negative of the other battery and still have twelve volts?
Or run a cable from positive of one battery to positive of other battery and negative to negative ?
I just want to put two batteries together for twelve volts to start motor and run lights with out lights going dim when you turn them on.
Batteries
