rod holder for trolling
jadeboy
#1 Post by jadeboy » Thu Jul 21, 2016 9:44 am
Any good clamp on rod holders for trolling out there skin comes all the way up to rail so rail is not open?
ralph
Re: rod holder for trolling
#2 Post by ralph » Thu Jul 21, 2016 10:30 am
That's my problem to. I hope somebody knows of one.
2015 90 HP Yamaha
2017 4WD GMC Canyon
Tankplunkett
#3 Post by Tankplunkett » Thu Jul 21, 2016 7:47 pm
I'm going to eventually get something like the ones in the pictures. Basically you can mount the base to your rails and then remove the pole holder when you aren't using it. I had one on an old john boat that I had and it seemed pretty sturdy, I never tried trolling with it though.
ralph
#4 Post by ralph » Thu Jul 21, 2016 9:22 pm
Problem for me is that it will get in the way of the mooring cover I think
2015 90 HP Yamaha
2017 4WD GMC Canyon
JBO
#5 Post by JBO » Thu Jul 21, 2016 10:06 pm
These work well for us:
https://www.amazon.com/gp/product/B001VESU56
https://www.amazon.com/gp/product/B001M4HTNO
https://www.amazon.com/gp/product/B001M4HT1G
We have about 10 or 12 different rod positions around the boat. We used the extensions on the rear of the boat to get the rods higher up. Many trolling rods have a long grip behind the reel and we found it difficult to get the rod in and out of the Scotty rod holders without the extensions.
joe20toon
#6 Post by joe20toon » Fri Jul 22, 2016 4:22 am
ralph wrote:Problem for me is that it will get in the way of the mooring cover I think
I'm looking for good rod holders too and, I completely forgot about the cover... The mounts will get in the way.
Yamaha Vmax SHO 115HP
wickerbill
#7 Post by wickerbill » Fri Jul 22, 2016 5:38 am
Most of the bases will allow mounting straight up or at 90 degrees of the base. You could mount the base to the inside of the rail....that should provide clearance for your cover.
Some people try to turn back their odometers. Not me, I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
2014 Berkshire STS 231RFC
115 Mercury 4 stroke
COTTS4x4
#8 Post by COTTS4x4 » Fri Jul 22, 2016 3:33 pm
Do any of you have ski tow bars you could use? This is what I did. I tipped the outside ones outward when I trolled in the keys.
rod holders.jpg (120.36 KiB) Viewed 7729 times
[b][i]
[/i][/b]
#9 Post by lakerunner » Fri Jul 22, 2016 3:55 pm
Tankplunkett wrote:I'm going to eventually get something like the ones in the pictures. Basically you can mount the base to your rails and then remove the pole holder when you aren't using it. I had one on an old john boat that I had and it seemed pretty sturdy, I never tried trolling with it though.
I use these on my toon. they stick up less than a 1/2 inch. Never interfered with my mooring cover.
They are very sturdy and though harder to find you can get left hand threads and right hand for each side of boat. I only use right thread but on left side replace wing nut with a reg nut and a lock nut to keep it from coming loose on a snag.
Also lots of configurations. My sofas stuck up to far for reg height holders so I got extended ones
You can see two of mine here
viewtopic.php?f=5&t=23751
