Replacement nose cone sources
RobZ71LM7
#1 Post by RobZ71LM7 » Mon Sep 05, 2016 4:07 pm
Guys, I need to find a replacement nose cone for a 23" diameter pontoon on an older boat. See the style in the picture, besides getting lucky on craiglist any ideas? It's for a friend who will weld it on himself.
pontoon nose cone 1.jpg (509.36 KiB) Viewed 4708 times
pontoon nose cone 2.jpg (490.19 KiB) Viewed 4709 times
Spend time at Nolin Lake, KY
rancherlee
Re: Replacement nose cone sources
#2 Post by rancherlee » Tue Sep 06, 2016 8:15 am
what is exactly wrong with it? if its just the splash fins I would clamp a 2x4's on both sides and and bend it back into place which MIGHT crack a weld but usually not. If it does crack that any decent aluminum welder should be able to weld em' up.
RobZ71LM7
#3 Post by RobZ71LM7 » Tue Sep 06, 2016 2:46 pm
The damaged cone is not the one pictured-the damaged one is "smashed" like a soda can and it would be much easier to just replace the cone.
#4 Post by Bamaman » Wed Sep 07, 2016 7:32 am
Toons being produced today are done with high tech welding/bending machinery.
However, the only way to build a nosecone is by hand, and it's a very specialized process.
If you can find someone with the skills and experience to build a nosecone, it'd still have to be built and purchased in pairs. And I have no idea, other than the original manufacturer, who could do such a job. And then it'd have to be welded in place properly.
