Trolling motor
Gonefishing
Trolling motor
#1 Post by Gonefishing » Sat Jul 07, 2018 3:25 pm
I have a 23 foot toon, 115 Yamaha looking to purchase a trolling motor. I have a bad back and knees. Looking at the minn Kota 80 pound trust riptide model 17992595. Anyone one have one if so how’s it working for you.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
Marc K
Re: Trolling motor
#2 Post by Marc K » Fri Jul 13, 2018 5:57 am
More is better, in order to be able to deal with variable conditions.
I have an older bow mounted Minn Kota 12v 55 lb. thrust with the basic foot pedal control setup. It pulls my boat along at 2 mph under calm conditions and I maintain a lot of battery power to get me to shore if needed.
I would think that 80 lbs. of thrust would be great - depending upon what you want to do, BUT I have no hands on experience with the newer higher tech units.
Marc
jediger
Re: Trolling motor
#3 Post by jediger » Fri Jul 13, 2018 7:56 pm
I have an 80# thrust Terrova with a 60 in shaft. The Terrova is the freshwater Riptide.
Works great. Maxes out at 2.5 or 3 mph depending on current and wind. Boat responds quickly, and holds spot pretty well again depending on wind.
Pinawa Bay, Manitoba
Steve7
Re: Trolling motor
#4 Post by Steve7 » Sat Jul 14, 2018 8:27 pm
I have a 22.5 foot Tritoon. I also have the 80 Terrova with 60” shaft. Works great. I also use an on board charger I bought from Minn Kota.
2016 Ford F250 6.7
Grizzly Flats, Ca
Gonefishing
Re: Trolling motor
#5 Post by Gonefishing » Sun Jul 15, 2018 10:10 am
Thanks guys for the responses decided to get the 24 volt saltwater Minn Kota 80 pound thrust, 60 inch shaft Ulterra with the auto deploy and stow. Also has automdepth control, spot lock and auto pilot. Just picked up the batteries, battery boxes, on board charger, circuit breaker and plug. Once I get that installed I will pick up the trolling motor.
Thanks again
2013 115 Yamaha
jediger
Re: Trolling motor
#6 Post by jediger » Mon Jul 16, 2018 5:36 am
:drool Totally jealous!
rancherlee
Re: Trolling motor
#7 Post by rancherlee » Mon Jul 16, 2018 7:50 am
I wish they would make a larger 12v, I stick with the 55# so I can charge the batteries with the outboard. It’s a pain to charge 24v setups when you are spending a week camping in a remote area. 55# keeps maintains direction on windy days but is running 10 of 10 to do it!
jadeboy
Re: Trolling motor
#8 Post by jadeboy » Mon Jul 16, 2018 10:23 am
not sure of the name for Yamaha but Merc calls there's troll control put in gear then you have a plus or minus button debending on if you want to go faster or slower each hit changes it by 50 rpm works great love mine I have a 115 check it out I can get under 2 mph with it it's really nice when it is windy out can hold a nice troll speed
