Trolling motor update
Gonefishing
While finally got my new Minnkota trolling motor mounted and all set up. Man is it a great investment was a little costly but I think while worth it. When you get old and arms and legs can’t take pulling and tugging the Minnkota ulterra is your answer. It has auto deploy and stow, spot lock and anchor feature all great options. Tried them all out and they all work great. Has a remote so everything can be done from any place on the boat.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
2013 115 Yamaha
Re: Trolling motor update
What kind of boat do you have and what pound thrust did you buy? Been looking at those things for quite a while now.Gonefishing wrote: ↑Thu Sep 06, 2018 3:37 pmWhile finally got my new Minnkota trolling motor mounted and all set up. Man is it a great investment was a little costly but I think while worth it. When you get old and arms and legs can’t take pulling and tugging the Minnkota ulterra is your answer. It has auto deploy and stow, spot lock and anchor feature all great options. Tried them all out and they all work great. Has a remote so everything can be done from any place on the boat.
Gonefishing
Riplipper
I have a 24 foot excursion with 115 Yamaha. I purchased the 80 pound thrust 24 volt Minnkota ulterra with I pilot. I think it is worth the cost for me that is. Auto deploy n stow with me having one artificial leg and bad knee on the other leg. It’s great. Not to mention the anchor mode and spot lock works great. No more throwing in and pulling up a anchor.
2013 115 Yamaha
2013 115 Yamaha
Retired OG
A couple months ago I watched a guy (by himself) launch a bass boat....he backed in and pulled out without getting out of his pickup....went and parked his rig then walked down to the dock, climbed in and took off...impressive.
Are you saying he backed it off the trailer, held position by the ramp, then brought it closer so he could climb in--all by remote? That's awesome! Now I want one!Retired OG wrote: ↑Tue Sep 11, 2018 7:07 amA couple months ago I watched a guy (by himself) launch a bass boat....he backed in and pulled out without getting out of his pickup....went and parked his rig then walked down to the dock, climbed in and took off...impressive.
Mark
Rush Lake, Atlanta, MI
Gonefishing
Yep you can do that. The trolling motor has auto deploy so all you have to do is make sure the motor is plugged in and turned on. Then once in the water using your remote you deploy the trolling motor set the speed and turn it all by remote and drive it to the dock. It’s realy neat. Only thing is you better remember to turn on and plug the motor in or you are going for a swim.
2013 115 Yamaha
2013 115 Yamaha
I've looked at the auto deploy and it's an aweome idea, but I have to go to the bow to open my bow gate anyway. Unless I remove the bowgate entirely, it just hasn't been worth the upgrade costs from my old 80# Terrova.
Pinawa Bay, Manitoba
Gonefishing
Have to open gate is true. But what I do is open it once and leave it open then I can run my trolling motor all day with no problem or can just shut the gate and raise the trim up or down
2013 115 Yamaha
2013 115 Yamaha
