Depth finder not working at speed
steve1313
#1 Post by steve1313 » Thu May 28, 2020 2:34 am
I have a basic transducer which feeds to my Simrad Go5. Most of the time, if I'm cruising over bout 25-30 MPH, it will stop showing the depth. If I slow down for a 30 seconds or so it will start reporting again. Does anyone else have this problem, and/or a solution?
Here's a picture showing where it's mounted.
Coldbrew
Re: Depth finder not working at speed
#2 Post by Coldbrew » Thu May 28, 2020 4:30 am
For what it's worth....mine does the same thing. I just figured they all did it so I never looked for a solution. :donno
2014 Premier Gemini 201
Tow Vehicle: 2019 F-150
Home Port: Newfound Lake, NH
jrolin1
#3 Post by jrolin1 » Thu May 28, 2020 5:04 am
It may need to be lowered slightly. Also tilt the back down slightly. It needs clean water at speed to read correctly.
jediger
#4 Post by jediger » Thu May 28, 2020 5:31 am
There's physics behind it. Finding Clean Water behind a pontoon can be challenging. See this webpage for an explanation.
https://www.louisianasportsman.com/fish ... different/
It is fixable, however. You can jury-rig something yourself like the column above or buy a commercial product like
https://johnnyraysports.com/product/jr- ... r-bracket/
Hope that helps!
Pinawa Bay, Manitoba
TheWhisker
#5 Post by TheWhisker » Thu May 28, 2020 6:20 am
jrolin has it right. I had the same problem when I installed mine, and thought it was just the way it is too. I found info on the intertubes about getting it a little below the log because of the disturbance they cause. I lowered mine just a bit below and it reads at speed now. I was happy to figure that out.
2007 Suncatcher 208C, Yamaha F90 fully rebuilt as a fishing vessel
1996 Ford E-350 conversion van, 460 w/4.10 Dana rear (the tow vehicle)
boocat
#6 Post by boocat » Thu May 28, 2020 12:24 pm
Hope that helps!
Thanks for that. I'm in the same "boat"
Liquid Asset
#7 Post by Liquid Asset » Thu May 28, 2020 7:52 pm
Yup pretty much what's been mentioned they all do it. I had a Garmin on my boat and replaced it with a lowrance for the mapping that was available. Forgot the model but it fit the hole in my dash. My friends with big boats run a couple screens one zoomed out and one zoomed in when cruising at speeds. They pretty much use mapping vs. the actual depth. Apparently things can sneak up on you too fast at any amount of speed!
Steiner
#8 Post by Steiner » Fri May 29, 2020 5:49 am
Doesn't go out until 25mph? Man, that's just bragging!
I gained 5mph usable just by tilting mine down one click....all the way to 15mph. Want to lower it but some of the islands we ride up on have reeeaaally mild grades where the whole toon will hit the sand when the wake boats go by. Tried the anchor buddy out last trip though and it worked well.
