Water Pump Impeller
Capt Sully
Water Pump Impeller
#1 Post by Capt Sully » Thu Aug 27, 2020 3:33 pm
I have a 90hp Yamaha and when I start it the water doesn't flow out. It's been sitting for a year and has 36hrs on the motor. Do you think the rubber water impeller has broken apart ? The impeller is in the lower shaft, I think ??
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
Marc K
Re: Water Pump Impeller
#2 Post by Marc K » Thu Aug 27, 2020 5:05 pm
First try cleaning the proof tubing path, starting at the outlet end.
Mine sat for 3-1/2 years and the impeller was a little stiff but still fully functional. I highly doubt that the impeller disintegrated so badly that you get zero flow in that time frame. I used a piece of weed eater line and a touch of carb cleaner to ream it out a bit. Once I got a little bit flow, it took off.
Capt Sully
#3 Post by Capt Sully » Thu Aug 27, 2020 6:04 pm
Thanks Marc.....I'm going to remove the inlet plates and take a look...
2012 Xcurison X23C
FVC USCG Auxiliary
Vietnam 66 / 67
#4 Post by Bamaman » Thu Aug 27, 2020 11:12 pm
Dirt dobbers love to fill up the pee hole.
If you're the original owner and you haven't run the engine without water, the chances of you needing a new impeller is nil. Yamaha impellers are really tough and long lasting.
Sometimes it takes a 30 seconds or longer for the water to flow out of the hole.
boocat
#5 Post by boocat » Fri Aug 28, 2020 3:10 am
sounds like a long time.
Steiner
#6 Post by Steiner » Fri Aug 28, 2020 3:34 am
Kinda what I was thinking. He's from GA and I am too....those things don't waste any time. Gotta be careful taking a crap outdoors because those things will plug your b-hole before you can get your pants up.
#7 Post by curtiscapk » Fri Aug 28, 2020 6:23 am
Mud dobbers! I have this in my tool compartment! Weed eater string long enough to run the whole tube.
RJFisher
#8 Post by RJFisher » Fri Aug 28, 2020 2:50 pm
On my Honda the hose came off the fitting.
Was here several years ago as RJF. Couldn’t find a way to revive that one so started new.
23’ Aqua Patio 90 hp Honda
Lund 1875 Crossover XS 150 Mercury 4st
