Tables
STEVEBRENDA
Tables
#1 Post by STEVEBRENDA » Fri Jul 30, 2021 1:52 pm
Any insight on a dining table that has decent drink holders? Ours are too shallow and are misleading to guests that think they will hold a drink while underway. They always fall out or tip over. Our last boat's table was the same deal. Everything online seems to have the same poor design.
Thanks!
2014 Regency 254
Mercury 250L Verado
Re: Tables
#2 Post by bansil » Fri Jul 30, 2021 2:09 pm
Can you replace them with new cup holders? Like these type
Amazon search boat cup holders
images (1).jpeg (5.24 KiB) Viewed 11582 times
Rick McC.
Re: Tables
#3 Post by Rick McC. » Fri Jul 30, 2021 3:23 pm
Most of the table tops that we’ve had have shallow, molded-in cup holders.
Those would be a fix if they were fastened in with nuts and bolts through the bottom drain holes to hold them on. A better looking solution would be to cut out the molded in holders, then replacing them with the deeper ones; mounting them flush.
We have so many cup holders in our boat that we don’t need to use the ones in the table. Actually, we’ve never used the table; we eat at the bar. I did set the table up once when I first got the boat to ensure that it set up properly.
Marc K
Re: Tables
#4 Post by Marc K » Fri Jul 30, 2021 7:29 pm
When we first got the boat, it was all about grilling and eating aboard. Over time, that has morphed so much that we pulled out the table floor mount and grill.
steve1313
Re: Tables
#5 Post by steve1313 » Sat Jul 31, 2021 3:05 am
I had the typical plastic table with the virtually worthless cupholders. Luckily my son-in-law had the skillset to make me a table and he used the cupholders that Bansil mentioned. It's a great option if you have someone who can create something custom.
Here's my original post with pics of the table.
http://pontoonforums.com/viewtopic.php? ... ilit=table
Re: Tables
#6 Post by bansil » Sat Jul 31, 2021 5:25 am
Steve, I remember that post :leghump
:biggrin2
Steiner
Re: Tables
#7 Post by Steiner » Sat Jul 31, 2021 5:27 pm
Glue solo cups in your existing cupholders.
