pontoon sides
leon phelps
pontoon sides
#1 Post by leon phelps » Mon May 17, 2010 11:30 am
Hello,
I have the standard fiberglass pontoon sides. I have already removed the rotted out wood and replaced it with it kept in with fiberglass. It stiffened it up nice. I now need to cover it from the inside? Any suggestions for what to use? I would like something that will never need replacing, like a composite sheet of something white. Not sure where to get it though. Originally it was plywood with a fabric cover. It rotted away at least once maybe twice before I got the boat.
Thanks for any input.
Re: pontoon sides
#2 Post by lakerunner » Mon May 17, 2010 11:39 am
What are standard fiberglass pontoon sides?
GXPWeasel
Re: pontoon sides
#3 Post by GXPWeasel » Mon May 17, 2010 11:40 am
What about that stuff made for bathrooms, that you can get in 4' x 8' sheets @ Lowe's / Home Depot ???
MIght be worth a shot. It's thin, and therefore could take a descent bent, but is made to repel water. Not sure if water proof. like this... http://www.homedepot.com/Building-Mater ... ogId=10053
Durante
Re: pontoon sides
#4 Post by Durante » Mon May 17, 2010 12:06 pm
You must share whatever your smoking so we can all understand what your talking about :smoke
Jason & Izzie
2009 G3 Elite
F225 w/ performance tritoons
Guntersville AL
leon phelps
Re: pontoon sides
#5 Post by leon phelps » Mon May 17, 2010 1:32 pm
Since this is the fourth pontoon that I own, and three of them have the same sides I would guess that this is the standard type of sides that are fiberglass. All three are different manufacturers but use the same type of fiberglass sides.
Something thicker than the .090 flimsy stuff would be needed.
two of my fiberglass sided pontoons
sides
WaltF
Re: pontoon sides
#6 Post by WaltF » Mon May 17, 2010 3:34 pm
Wow...
What year are those things? 70's?
Also, flat bottoms on the toons...
Cool looking! :nana
Colorado Springs, CO.
leon phelps
Re: pontoon sides
#7 Post by leon phelps » Mon May 17, 2010 4:22 pm
Middle to late 80's. Most aluminum toons will be rusted out before these get another decking.
The toons are somewhat "D" shaped. They also have a stringer up the bottom for times when they hit the ground.
Re: pontoon sides
#8 Post by lakerunner » Mon May 17, 2010 4:55 pm
WOW now thats some tough sides. The POS alum that bends when a bug hits it they use on toons now is real S_ _T sides
leon phelps
Re: pontoon sides
#9 Post by leon phelps » Mon May 17, 2010 4:58 pm
lakerunner wrote:WOW now thats some tough sides. The POS alum that bends when a bug hits it they use on toons now is real S_ _T sides
yeah and I get some comment that I must be smoking something.
I honestly would never buy an aluminum toon after seeing some that are ten years old and then seeing some fiberglass ones.
Re: pontoon sides
#10 Post by HandymanHerb » Mon May 17, 2010 5:46 pm
I haven't seen none of them in Florida
Durante
Re: pontoon sides
#11 Post by Durante » Mon May 17, 2010 8:49 pm
Leon, the smoking something jab was put out there because after a few minutes on tring to decypher your first sentence, I though maybe, just maybe there was some smoking going on. :donno
awe well, guess i was wrong??? :roll:
Jason & Izzie
2009 G3 Elite
Guntersville AL
Re: pontoon sides
#12 Post by badmoonrising » Mon May 17, 2010 9:55 pm
The PC cabin is made from foam core laminate, same stuff that is used in sun rooms and RVs. I believe Lowes or Home Depot carries it. That would work for you....
slingshot
Re: pontoon sides
#13 Post by slingshot » Tue May 18, 2010 4:44 am
Aluminum does not rust. Only steel or iron rusts. Aluminum will create Aluminum Oxide which is stronger than aluminum and appears as a whiteish color. That’s why they last so long. There are aluminum toons out there made back in the 50's that are just fine. Fiberglass is a good product but much heavier than aluminum which is why most pontoon boats are made out of the stuff.
2007, 2570 Crest LE II
Yamaha F150
Re: pontoon sides
#14 Post by margaritaman » Tue May 18, 2010 6:16 am
But hey Leon, if you were smoking can you share some of that stuff? :lol3 :lol3 :lol3
leon phelps
Re: pontoon sides
#15 Post by leon phelps » Tue May 18, 2010 9:54 am
I'll try to be more to the point with my comments about standard fiberglass sides next time.
