Is this normal?
Clearwater262
Is this normal?
#1 Post by Clearwater262 » Sat Jun 28, 2014 7:12 am
Is oil coming out of the "vent" screw normal? Also, what is the soft rubber piece hanging off the motor in picture 3? Thanks
2003 Harris Flotebote Royal Heritage 260
Mercury 60 Bigfoot
Clearwater262
Re: Is this normal?
#2 Post by Clearwater262 » Sat Jun 28, 2014 7:13 am
Looks like the soft rubber piece is in picture #1. Sorry for the big pics, I thought downsizing them by 25% would be enough.
Mercury 60 Bigfoot
Re: Is this normal?
#3 Post by HandymanHerb » Sat Jun 28, 2014 7:21 am
480 x 640 works good on the forum
jimrs
Re: Is this normal?
#4 Post by jimrs » Sat Jun 28, 2014 8:19 am
With the screw removed or real loose oil should come out of the vent if the lower unit is full. If it's tight then you might be missing a gasket under the screw head. Not only will it loose oil but let water in. The piece your talking about is a hook up for a speedo meter. I resized your pictures.
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
Re: Is this normal?
#5 Post by lakerunner » Sat Jun 28, 2014 9:48 am
I think Merc's use O rings to seal lower unit screws
BoatCop
Re: Is this normal?
#6 Post by BoatCop » Sat Jun 28, 2014 12:24 pm
Mercury uses fiber washers for their drain and vent screws.
If it's leaking, there could be a few causes:
Washer missing
Washer old (dried up and brittle)
Washer split/broken
Washer doubled up (previous service didn't remove old washer and put new one on top of it)
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
Re: Is this normal?
#7 Post by Bryden24shp » Sat Jun 28, 2014 5:04 pm
BoatCop wrote:Mercury uses fiber washers for their drain and vent screws.
Washer missing
Washer split/broken
#2.... Yep!
babock
Re: Is this normal?
#8 Post by babock » Sun Jun 29, 2014 12:30 pm
You need to replace those every time you change your gear lube.
Mercury 90 4 stroke
