Is this normal?
Clearwater262
Is this normal?
Is oil coming out of the "vent" screw normal? Also, what is the soft rubber piece hanging off the motor in picture 3? Thanks
- 20140620_125403.jpg (1.4 MiB) Viewed 2059 times
- 20140620_125357.jpg (1.61 MiB) Viewed 2059 times
- 20140620_125347.jpg (1.07 MiB) Viewed 2059 times
2003 Harris Flotebote Royal Heritage 260
Mercury 60 Bigfoot
Mercury 60 Bigfoot
Clearwater262
Re: Is this normal?
Looks like the soft rubber piece is in picture #1. Sorry for the big pics, I thought downsizing them by 25% would be enough.
Mercury 60 Bigfoot
Mercury 60 Bigfoot
Re: Is this normal?
With the screw removed or real loose oil should come out of the vent if the lower unit is full. If it's tight then you might be missing a gasket under the screw head. Not only will it loose oil but let water in. The piece your talking about is a hook up for a speedo meter. I resized your pictures.
- New_20140620_125403.jpg (294.84 KiB) Viewed 1997 times
- New_20140620_125357.jpg (316.78 KiB) Viewed 1993 times
- New_20140620_125347.jpg (254.97 KiB) Viewed 1989 times
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
Elm Grove, La
Lake Bistineau
Re: Is this normal?
I think Merc's use O rings to seal lower unit screws
Re: Is this normal?
Mercury uses fiber washers for their drain and vent screws.
If it's leaking, there could be a few causes:
Washer missing
Washer old (dried up and brittle)
Washer split/broken
Washer doubled up (previous service didn't remove old washer and put new one on top of it)
Washer missing
Washer split/broken
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
2016 Chevy Tahoe
2009 GMC Sierra
Re: Is this normal?
#2.... Yep!BoatCop wrote:Mercury uses fiber washers for their drain and vent screws.
Washer missing
Washer split/broken
Re: Is this normal?
You need to replace those every time you change your gear lube.
Mercury 90 4 stroke
Mercury 90 4 stroke
