When to use Blower?
Johnny.Mac
When to use Blower?
Hello Everyone,
I am new to owning a boat and this will be the first of many posts for me I’m sure. I recently purchased a 1992 Bass Buggy 18 with a 50 Horse 2 cycle Johnson. Can someone please explain to me when I should pull out my blower and when it should be pressed back in?
- 2015062495142947.jpg (24.84 KiB) Viewed 6111 times
Re: When to use Blower?
Blowers are typically used on Inboards and I/O boats. They are to remove the possibility of an explosion from trapped gas fumes.
I would venture to say that a previous owner had this switch laying around and installed it. I would operate it and see what it turns on, or trace the wires.
or I could be totally off point, and it operates the Hyper Drive system that allows you and your 50 hp to reach Ludacris speed.
maybe it turns on the co-captain?
to turn on her blower!PlaynDoc wrote:maybe it turns on the co-captain?
- NonHyphenAmerican
Actually, I always wondered where that switch was....curtiscapk wrote:to turn on her blower!PlaynDoc wrote:maybe it turns on the co-captain?
But if the only place her blower can be turned on is on the toon, I'm going to have to find a REALLY secluded cove...
I don't have anything to add but I wanted in on the "her blower" thread!NonHyphenAmerican wrote:Actually, I always wondered where that switch was....curtiscapk wrote:to turn on her blower!PlaynDoc wrote:maybe it turns on the co-captain?![]()
Serously, sjp1311 was correct, unless you have a compartment like a fuel compartment there should be no need for a blower. I have only seen blowers in inboard engine compartments.
- NonHyphenAmerican
MAYBE IT TURNS THIS BLOWER ON>>>>>>>>>
Very cool! She is a real talent...
playcat
JC 266 TriToon
Kerr Reservoir, VA
JC 266 TriToon
Kerr Reservoir, VA
Did you buy the boat from a sketchy looking dude named Max?
Tim
Tim
- 04Ram2500Hemi
Re: MAYBE IT TURNS THIS BLOWER ON>>>>>>>>>
LOL!!!NonHyphenAmerican wrote:
The Truck:
2012 Ram Power Wagon (not exactly 100% stock)
The Boat:
2015 Starcraft Stardeck 216 Starlounger
The Boat:
I've never seen a blower on an outboard boat either. To the OP, blowers are used on inboard/outboard boats, or straight inboard boats. Their purpose is to remove fuel vapors from the engine compartment before starting the boat. That prevents any sparks (should not be any) from igniting fuel vapors (should not be any) trapped in an engine compartment, causing an explosion. I think the recommendation is to use them for 5 minutes prior to starting, and I think they are recommended when idling as well, but I could be wrong about that. In a perfect world, there will never be fuel vapors in the engine compartment, and there will be no sparks to ignite them, either. However, there are a few of these explosions every year.
On an outboard, I don't know what its purpose would be.
BTW, I know a lot of people with I/O's and inboards do not use them. I have to believe some of those explosions each year could be prevented.
Wow, everyone else's answer was a LOT more fun than mine!
2007 South Bay 925 Tri-toon
5.7 Volvo I/O
5.7 Volvo I/O
