honda outboard control feel
ducati1212
#1 Post by ducati1212 » Mon Jun 22, 2015 4:17 am
My 20 avalon has a 90 honda outboard and I have a question about the control lever. Its a little loose in that if I put the boat to say 5000 RPM when I take my hand off the control it goes back down.
Is there just a way to tighten up the control lever so it has more resistance
2015 Avalon LSZ 2085
90 HP Honda VTEC
tuned
Re: honda outboard control feel
#2 Post by tuned » Mon Jun 22, 2015 4:21 am
Yep. They all have a 'friction screw' that needs to be tightened just a bit. You will have to look around for it or get a diagram. It's usually at the front or rear of the box. Good luck.
-dirt-
#3 Post by -dirt- » Mon Jun 29, 2015 9:42 am
I think this is what you are needing.
ducati1212
#4 Post by ducati1212 » Tue Jun 30, 2015 4:59 am
ahhh nice I have the top mount and was not finding much info I thought it had no adjuster. So its under the top cover I need to remove that and then adjust.
90 HP Honda VTEC
