Homemade ski/tube pylon-bar.
cuttymcgavin
Re: Homemade ski/tube pylon-bar.
looks awesome, what kind of material did you use and what thickness?
1992 22' Parti Kraft (Rebuilt 2009) Tri toon
2011 Mercury 150hp Optimax
2009 Shorelander Trailer
- kryptonite
It's 1 1/4" black pipe-tubing.
1 1/4" ID
1.66" OD
.14" Wall
Bottom plate is 2" wide x 1/4" flat iron
1 1/4" ID
1.66" OD
.14" Wall
Nice job! Only concern I would have is if your tow rope will pop off when the person/persons you are towing fall off or let go and you get the loose rope slap going. With the ring design you loop around the ring and thread the tow rope loop over the rod (in your design a bolt) to prevent this...maybe a larger washer (fender washer) on top of your bushing would have the same effect? Keep us posted how it works...I have a very similar design being made for me and I was thinking of buying one of the premade rings and mounting it to my tubing. Again...nice job with the design.
TunaBarge
Rod
1994 SunStar 20'
1996 Merc 75 hp Force (for now)
New London, Wi
Rod
1994 SunStar 20'
New London, Wi
- kryptonite
You just have to loop and twist the rope and wrap it around again, that makes the rope fit tighter so it won't pop off. I had a pylon on my ski boat that had something similar to what I built, never had an issue. Hopefully get to try it out this weekend, but I might be stuck at work all weekend.TunaBarge wrote:Nice job! Only concern I would have is if your tow rope will pop off when the person/persons you are towing fall off or let go and you get the loose rope slap going. With the ring design you loop around the ring and thread the tow rope loop over the rod (in your design a bolt) to prevent this...maybe a larger washer (fender washer) on top of your bushing would have the same effect? Keep us posted how it works...I have a very similar design being made for me and I was thinking of buying one of the premade rings and mounting it to my tubing. Again...nice job with the design.
- kryptonite
Got it mounted up the other night. Used it on the 4th. Worked great. My son enjoyed knee boarding much better as he was able to cut in and out of the wake easier. It was also great on the tube.
- IMAG0095_VGA.jpg (106.04 KiB) Viewed 11256 times
- IMAG0091_VGA.jpg (101.35 KiB) Viewed 11254 times
- IMAG0089_VGA.jpg (104.26 KiB) Viewed 11251 times
Nice job. Now how much are you charging to build each of us non-metal types one of these? or at least the plans?
"If 10% is good enough for God, then 9% should be just fine for the Federal Government"
Herman Cain - Aug 18 2011
1997 90hp 2 Stroke Merc
1997 Sun Tracker Fishin' Barge 21
I like the looks of that I am trying to figger a way to add one now.
didn't plan one when I rebuilt back a few years ago.
