Homemade ski/tube pylon-bar.
cuttymcgavin
Re: Homemade ski/tube pylon-bar.
#16 Post by cuttymcgavin » Tue Jun 28, 2011 5:51 pm
looks awesome, what kind of material did you use and what thickness?
1992 22' Parti Kraft (Rebuilt 2009) Tri toon
2011 Mercury 150hp Optimax
2009 Shorelander Trailer
kryptonite
#17 Post by kryptonite » Tue Jun 28, 2011 6:24 pm
It's 1 1/4" black pipe-tubing.
1 1/4" ID
1.66" OD
.14" Wall
Bottom plate is 2" wide x 1/4" flat iron
TunaBarge
#18 Post by TunaBarge » Wed Jun 29, 2011 5:56 am
Nice job! Only concern I would have is if your tow rope will pop off when the person/persons you are towing fall off or let go and you get the loose rope slap going. With the ring design you loop around the ring and thread the tow rope loop over the rod (in your design a bolt) to prevent this...maybe a larger washer (fender washer) on top of your bushing would have the same effect? Keep us posted how it works...I have a very similar design being made for me and I was thinking of buying one of the premade rings and mounting it to my tubing. Again...nice job with the design.
TunaBarge
Rod
1994 SunStar 20'
1996 Merc 75 hp Force (for now)
New London, Wi
kryptonite
#19 Post by kryptonite » Wed Jun 29, 2011 6:53 am
TunaBarge wrote:Nice job! Only concern I would have is if your tow rope will pop off when the person/persons you are towing fall off or let go and you get the loose rope slap going. With the ring design you loop around the ring and thread the tow rope loop over the rod (in your design a bolt) to prevent this...maybe a larger washer (fender washer) on top of your bushing would have the same effect? Keep us posted how it works...I have a very similar design being made for me and I was thinking of buying one of the premade rings and mounting it to my tubing. Again...nice job with the design.
You just have to loop and twist the rope and wrap it around again, that makes the rope fit tighter so it won't pop off. I had a pylon on my ski boat that had something similar to what I built, never had an issue. Hopefully get to try it out this weekend, but I might be stuck at work all weekend.
kryptonite
#20 Post by kryptonite » Tue Jul 05, 2011 11:29 am
Got it mounted up the other night. Used it on the 4th. Worked great. My son enjoyed knee boarding much better as he was able to cut in and out of the wake easier. It was also great on the tube.
jeffybear
#21 Post by jeffybear » Tue Jul 05, 2011 2:08 pm
Nice job. Now how much are you charging to build each of us non-metal types one of these? or at least the plans?
"If 10% is good enough for God, then 9% should be just fine for the Federal Government"
Herman Cain - Aug 18 2011
1997 90hp 2 Stroke Merc
1997 Sun Tracker Fishin' Barge 21
#22 Post by RcgTexas » Mon Jun 11, 2018 6:56 pm
I like the looks of that I am trying to figger a way to add one now. :thumbsup didn't plan one when I rebuilt back a few years ago.
