Whatever you use, make sure you use plenty of scope.
Chain- use a length of chain to keep it set.
I finally used a chain this past year and I couldn't believe the difference it makes. I was just using a river style on a muddy bottom, the chain and proper scope makes the holding power triple by my estimation.
Best Anchor?
- kryptonite
Re: Best Anchor?
- Ron Burgundy
Re: Best Anchor?
Bamby wrote:I found a redneck solution that may actually work for your situation, and maybe Greg's too....Ron Burgundy wrote: I like the idea of the power pole, but like you said they are too expensive. Been thinking about getting a 'shore spike' since most of my anchoring is on the beach. Sometimes if it's real windy I'll set an anchor when fishing, but usually I just drift. Last time I was fishing in wind the anchor just dragged on the bottom anyway. I pulled it up so I didn't disturb any turtle grass.
http://brotherhood-of-catfishermen.com/ ... 1037517260
Thanks a pretty good idea. Thanks for the tip. Might have to give it a try.
- Dragboatdad
Re: Best Anchor?
I couldn't agree more!kryptonite wrote:Whatever you use, make sure you use plenty of scope.
"Never slow down never grow old"
Re: Best Anchor?
Ron if you do this, go to an electrical supply and get 2 sticks of 1 1/2" schedule 80 nonmetallic rigid conduit and 2 2" couplers. That is heavy duty PVC pipe that is UV protected.
