PDB is Offline
#16 Post by HandymanHerb » Fri Oct 27, 2006 6:42 pm
Diddyjo wrote:
HandymanHerb wrote:Well i had it for a second, took me two trys to respond to toons post and then it was gone again
That's because it's in the middle of the night...what the heck Herb, don't you sleep?? :D
Sometimes, between 1am till 5:30 am, then I up and going again, someone got to make sure the jokes are read :D
#17 Post by HandymanHerb » Mon Oct 30, 2006 5:34 pm
Oh where oh where did my PDB go, the web took her away from me.
PDB is in limbo land again, missing in action, a few links short of a web site.
If they keep dispearing and we have everyone over here after while
#18 Post by HandymanHerb » Mon Oct 30, 2006 8:30 pm
Dam it's driving me crazy, not there, then there it is and then before you know it it's gone again.
Lindsay90
#19 Post by Lindsay90 » Wed Nov 08, 2006 4:24 pm
This place is working we should get everyone here, plus I lost my password there and I have emailed the mods there to get it back but no one emails back.
2003 Fisher Liberty 200
#20 Post by HandymanHerb » Sat Nov 11, 2006 8:25 am
Did you try Brady He can get it done
Lindsay90
#21 Post by Lindsay90 » Sat Nov 11, 2006 3:34 pm
I am in now, I tell you I have emailed many times with no one getting back to me so I had to start a new member name. But I can now use my old one thanks.
Heatman
#22 Post by Heatman » Tue Nov 21, 2006 4:39 am
This is what I'm seeing this morning.
Error Executing Database Query.
[Macromedia][SQLServer JDBC Driver]Error establishing socket. No route to host
The error occurred in /WebFS/PontoonDeckboat/fusetalk/forum/include/common/globalsettings.cfm: line 22
Called from /WebFS/PontoonDeckboat/fusetalk/forum/cfc/ini/init.cfm: line 5
Called from /WebFS/PontoonDeckboat/fusetalk/forum/cfc/fusetalk.cfc: line 3
Called from /WebFS/PontoonDeckboat/fusetalk/forum/Application.cfm: line 28
Called from /WebFS/PontoonDeckboat/fusetalk/forum/include/common/globalsettings.cfm: line 22
20 : <cfset FTTMP_COMSETCACHE = CreateTimeSpan(0,0,0,0)>
21 : </cfif>
22 : <cfquery name="request.qGetSettings" datasource="#ds#" username="#dsusername#" password="#dspassword#" cachedwithin="#FTTMP_COMSETCACHE#">
23 : select * from ftdb_communitysettings
24 : </cfquery>
SQL select * from ftdb_communitysettings
DATASOURCE pontoonforums
Please try the following:
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 6.0; AOL 9.0; Windows NT 5.1; SV1; .NET CLR 1.1.4322)
Remote Address 152.163.100.65
Referrer
Date/Time 21-Nov-06 04:38 AM
Stack Trace (click to expand)
at cfglobalsettings2ecfm1227608760.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/include/common/globalsettings.cfm:22) at cfinit2ecfm555508242.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/cfc/ini/init.cfm:5) at cffusetalk2ecfc1997825845.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/cfc/fusetalk.cfc:3) at cfApplication2ecfm813913223.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/Application.cfm:28) at cfglobalsettings2ecfm1227608760.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/include/common/globalsettings.cfm:22) at cfinit2ecfm555508242.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/cfc/ini/init.cfm:5) at cffusetalk2ecfc1997825845.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/cfc/fusetalk.cfc:3) at cfApplication2ecfm813913223.runPage(/WebFS/PontoonDeckboat/fusetalk/forum/Application.cfm:28)
java.sql.SQLException: [Macromedia][SQLServer JDBC Driver]Error establishing socket. No route to host
at coldfusion.server.j2ee.sql.pool.JDBCPool.requestConnection(JDBCPool.java:677)
at coldfusion.server.j2ee.sql.pool.JDBCManager.requestConnection(JDBCManager.java:123)
at coldfusion.server.j2ee.sql.JRunDataSource.getConnection(JRunDataSource.java:138)
at coldfusion.server.j2ee.sql.JRunDataSource.getConnection(JRunDataSource.java:125)
at coldfusion.sql.DataSrcImpl.getCachedConnection(DataSrcImpl.java:120)
at coldfusion.sql.DataSrcImpl.getConnection(DataSrcImpl.java:75)
at coldfusion.sql.SqlImpl.execute(SqlImpl.java:207)
at coldfusion.tagext.sql.QueryTag.setupCachedQuery(QueryTag.java:595)
at coldfusion.tagext.sql.QueryTag.doEndTag(QueryTag.java:443)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:147)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:357)
at coldfusion.runtime.CfJspPage._emptyTag(CfJspPage.java:1871)
at coldfusion.runtime.TemplateProxyFactory.resolveName(TemplateProxyFactory.java:290)
at coldfusion.runtime.TemplateProxyFactory.resolveFile(TemplateProxyFactory.java:77)
at coldfusion.runtime.TemplateProxyFactory.resolveName(TemplateProxyFactory.java:568)
at coldfusion.runtime.CFPage.CreateObject(CFPage.java:5038)
at coldfusion.tagext.lang.ObjectTag.doStartTag(ObjectTag.java:193)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:62)
at coldfusion.filter.CfincludeFilter.include(CfincludeFilter.java:30)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:93)
at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:43)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:80)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:47)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:35)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:43)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.CfmServlet.service(CfmServlet.java:105)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:252)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:192)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:348)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:451)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:294)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
Sheridan, Indiana
Toontroller
#23 Post by Toontroller » Tue Nov 21, 2006 6:43 am
Getting the same thing Heatman.
1991 Sun Tracker Bass Buggy 16
Evinrude 40
Bet I have the shortest Toon on this board also
#24 Post by HandymanHerb » Tue Nov 21, 2006 7:36 am
I got back in and shocked the site :lol:
They forgot to pay the bill again
Texoma Toon
#25 Post by Texoma Toon » Tue Nov 21, 2006 7:39 am
I am still locked out :(
Bob
Error Occurred While Processing Request
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debugging Settings, and select the Robust Exception Information option.
Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322)
Remote Address 64.183.239.22
Referrer
Date/Time 21-Nov-06 07:19 AM
Toontroller
#26 Post by Toontroller » Tue Nov 21, 2006 7:40 am
Weve been BLACKBALLED :shock:
Hey Bob welcome over here too!
You chasing any stipers this Holiday weekend?
Evinrude 40
Texoma Toon
#27 Post by Texoma Toon » Tue Nov 21, 2006 7:45 am
YOU bet I am!!! Stuffing myself Thursday then leaving Friday for the lake. If the wind stays down I hope to do well.
Bob
Toontroller
#28 Post by Toontroller » Tue Nov 21, 2006 7:52 am
I'm hoping Whitney will give up some fish as well, Leaving tomorrow evening to set up and fish and nap on the boat!
Gotta love 70 degrees on Thanksgiving day :D
And yes thats above zero for the NORTHERN FOLK................
Hey Bob, do you post on the Texas Fishing Forum as well?
Evinrude 40
Texoma Toon
#29 Post by Texoma Toon » Tue Nov 21, 2006 7:57 am
Thanks for the welcome over here btw :)
What's up with the site this morning?
Bob
#30 Post by HandymanHerb » Tue Nov 21, 2006 8:53 am
Well the PDB came up finely
70 damm we not supposed to get over 50 in Florida, I was thinking about taking the toon to Dinner and ride people around later but nobody going to want to go on the water at 50, unless your going for fish
