Stupid trailer wheels
MPosey519
#1 Post by MPosey519 » Sat Mar 30, 2013 10:05 am
I'm having a hell of a time finding some new damn trailer wheels for my trailer...
14" 5x5.5" lugs...they're nowhere to be found!
Michael
Rough River Lake, Kentucky
50 HP 2003 2-stroke Mercury
Re: Stupid trailer wheels
#2 Post by Bamaman » Sat Mar 30, 2013 2:33 pm
Wheels ought to be easily found online. ChampionTrailers.com is where I look to for trailer parts.
They're probably the same wheels that a Ford uses--same pattern. They can usually be ordered in from any large tire distributor and received within 12-24 hours.
There are relatively few vehicles using 14" tires anymore. Ford Ranger, and that's about all. It's used tires for my utility trailer I've had problems finding.
jimrs
#3 Post by jimrs » Sat Mar 30, 2013 3:20 pm
Most trailer manufactures use either ford or gm wheel lug patterns. But size of tires to fit your trailer can be hard to find sometimes.
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
MPosey519
#4 Post by MPosey519 » Sat Mar 30, 2013 7:25 pm
I'm finding plenty of 14" 5x5, or 5x4.5, but the 5x5.5 are very few, and they are way more than I want to spend(I'm looking for under $50) I might try a 5x5 and see if they fit, it's just for a spare s I'm not overly worried
Michael
#5 Post by ROLAND » Sun Mar 31, 2013 2:50 am
take a look at etrailer.com
MH Hawker
#6 Post by MH Hawker » Sun Mar 31, 2013 5:01 am
i have been dealing with this company
http://www.easternmarine.com/
kryptonite
#7 Post by kryptonite » Sun Mar 31, 2013 8:05 am
My old trailer had some 5 on 5.5. They are rare and expensive. My local tire shop was able to get them.
If still no luck, go to an ag implement dealer. The trailers they use for combine header haulers use that bolt pattern I believe.
kryptonite
#8 Post by kryptonite » Sun Mar 31, 2013 8:14 am
Just saw you were loking under 50 bucks. Thats not gonna happen.
Just for a spare you could fabricate the bolt pattern if you know someone that is a welder.
The 5 on 5 will not fit, dont waste your money.
#9 Post by badmoonrising » Sun Mar 31, 2013 8:22 am
MH Hawker wrote:i have been dealing with this company
These guys are 15 minutes from my house and can get anything for old, obsolete trailers and are good with unusual stuff. Even my late 60's era aluminum trailer I have for my Starcraft. Best prices around too.
Bamby
#10 Post by Bamby » Sun Mar 31, 2013 8:33 am
I've not had any luck sourcing them either 5x5.5 must not be utilized much by any trailer manufacture. I also haft to add this if I were you I'd also be searching for a spare replacement hub source. Often on the road with a wheel bearing failure the hub is also often compromised and I have the feeling a replacement hub kit is also going to be as elusive or maybe more so than than the spare tire you're attempting to obtain now.
blackberg
#11 Post by blackberg » Sun Mar 31, 2013 1:56 pm
check ebay,
its where I found my odd size trailer wheels for my pontoon
http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40
-bb
kryptonite
#12 Post by kryptonite » Sun Mar 31, 2013 6:57 pm
Bamby wrote:I've not had any luck sourcing them either 5x5.5 must not be utilized much by any trailer manufacture. I also haft to add this if I were you I'd also be searching for a spare replacement hub source. Often on the road with a wheel bearing failure the hub is also often compromised and I have the feeling a replacement hub kit is also going to be as elusive or maybe more so than than the spare tire you're attempting to obtain now.
This is good advice. Especially if you travel very far from home. I was going to replace spindles hubs and all on my old trailer, but it's only 1/4 mile to the ramp, so I didn't end up changing them. In the long run it might be cheaper thopugh if you plan on keeping the trailer.
MPosey519
#13 Post by MPosey519 » Mon Apr 01, 2013 4:20 am
I'll be trailering about a mile during the summer, about an hour whenever I need to actually bring it home to work on it.
Michael
