Towables; how much is too much?
68dodgeramman
#1 Post by 68dodgeramman » Mon Jun 23, 2014 3:41 am
Ok, so I'm looking at the Chariot Warbird 3. But as I'm thinking about buying it I'm also thinking that, "hey, maybe this tube with 3 - 14yr. olds is gonna be too much for the 150hp to pull!" So maybe I should get the Chariot Warbird 2. So what do you think, Warbird 2 or 3?
2014 Xcursion X23RF "Tooned Out"
XS tube pkg.
150hp Evinrude ETEC
rancherlee
Re: Towables; how much is too much?
#2 Post by rancherlee » Mon Jun 23, 2014 4:21 am
to much for a 150hp, NO. I have some success getting a HUGE 4 person Mable/big brawler outside the wake behind my 70hp with kids on it, Adults is a different story. I find there is little difference between pulling a small 2 person tube and a huge 4+ person tube, if you can pull a small one it will handle a bigger one. With my 70hp I need to run with just the captain and a spotter on the toon but my home brewed 3 logger is only ~1800# WITH the motor and a full tank of gas.
Ray Jr.
#3 Post by Ray Jr. » Mon Jun 23, 2014 4:53 am
We have the warbird 2, we have had 3 adults on it and have no problems slinging it out of the wake with the 150 on our Premier, but we also have the booster ball, It keeps the rope out the water and makes it easier to get tubes out of the wake. Also make sure the tube is fully inflated, if it is under inflated I can feel the extra drag when I pull it, and it is much harder to give a "good" ride, but when fully inflated it glides over the water nicely.
Here are a few pics
2010 150 HP Mercury Optimax
JohnO
#4 Post by JohnO » Mon Jun 23, 2014 10:23 am
I routinely pull a Super Mable (3 person similar to the warbird) with three adults. I try to keep them at about 25mph and I turn between 3500 and 4000rpm to do it. I can easily get them over 30mph if I go WOT
You'll have no problem with this.
175 Yamaha VMax
2016 Ford F150
PlaynDoc
#5 Post by PlaynDoc » Mon Jun 23, 2014 6:46 pm
here's what i have... the airhead 2 person hot dog...
http://www.amazon.com/AIRHEAD-HD-2-Doub ... og+towable
here is it being towed by my pontoon... today.
GXPWeasel
#6 Post by GXPWeasel » Tue Jun 24, 2014 6:13 am
My little 90hp motor, on my 26' toon, can pull 2 adults, and give an ok ride. I would guess that with an extra 60hp, you should be able to sling 3 kids on a tube, pretty easilly.
68dodgeramman
#7 Post by 68dodgeramman » Tue Jun 24, 2014 11:26 am
Well, I think it's the 3! Thanks everybody. And the pics and video looked like a blast and is making me want to order this sooner than later, lol! Thanks again.
XS tube pkg.
150hp Evinrude ETEC
PlaynDoc
#8 Post by PlaynDoc » Tue Jun 24, 2014 5:42 pm
oh.... we used to have/use a 3 person, sit-up type tube... worked well... TOO BIG to fit convenient into boat when hauling.... and TOO HEAVY to lift into boat when hauling...
keep those things in consideration, too
this 2 person hot dog fits real well right on our sun pad, and doesn't blow off, even at WOT... and light... very light to lift from water...
GXPWeasel
#9 Post by GXPWeasel » Wed Jun 25, 2014 11:01 am
[quote="PlaynDoc"]oh.... we used to have/use a 3 person, sit-up type tube... worked well... TOO BIG to fit convenient into boat when hauling.... and TOO HEAVY to lift into boat when hauling...
quote]
True. I will typically keep my tube in the water, but I tie it up to a deck cleat, really closely behind the boat, so no water gets thrown into it from the boat's wake. Seems to not hurt our speed one bit, since there isn't really much drag on an empty tube. This frees up all sorts of deck space too.
PlaynDoc
#10 Post by PlaynDoc » Thu Jun 26, 2014 7:59 pm
GXPWeasel wrote:
PlaynDoc wrote:oh.... we used to have/use a 3 person, sit-up type tube... worked well... TOO BIG to fit convenient into boat when hauling.... and TOO HEAVY to lift into boat when hauling...
quote]
that outta work just fine for you.
rockhound
#11 Post by rockhound » Fri Jun 27, 2014 6:43 am
we also have a big mable three person tube, i have not pulled her with the pontoon yet. one reason i moved the fencing and opened up 30 inches on the front swim deck was for storing the tube while cruising.
the tube was a big factor in losing the runabout and getting a pontoon
Obama: finally gone, MAGA
Prestn
#12 Post by Prestn » Thu Jul 03, 2014 10:57 am
I am pulling a 2 person flat tube and I can really swing them around when I get 3 teenagers on it. When I have 1 or 2 its not so easy but I can get them outside the wake.
22' 2005 Lowes Trinidad
90 HP 4stroke
Tracy Ferry Marina, Lake Norfork, AR
landlockedsailor
#13 Post by landlockedsailor » Fri Jul 04, 2014 11:54 am
We have a Big Mable, not sure how our 60 hp will do at pulling it. Considering pulling with big waverunner. Anybody doing that?
Landlocked Sailor
