Heard a bit of water sloshing in the front right toon chamber. Spent a while trying to get at the small red plastic plug in the top of the toon, finally got a hold of it and took it out. Lowered some tubing down in to see if there was enough water to siphon out but couldn't get any. Lowered a string straight down to the bottom and that came up dry, so I guess there isn't that much in there and its all up towards the front. The pontoon doesn't sit uneven in the water, but if I could I wanted to get the water out.
Then.... Time to put the plug back in. Barely started to tighten it and the top broke right off with the threading still in the hole.
Any ideas on the best way to get the plastic out, or how to proceed from here? I've seen some people heated up the plastic to the point they could wipe it out, some others just plugged up the top and left the plastic in.
Oh, it's on a 2001 suntracker 21 party barge.
