PDB is Offline
PDB is Offline
Oh were oh were did PDB go, or I'm I the only one getting in, good thing Rock Star is on tonite
- looneytoons
- looneytoons
I'm getting some thing new anyway
Error Occurred While Processing Request
Could not find the included template include/ini/cgivariables.cfm.
Note: If you wish to use an absolute template path (e.g. TEMPLATE="/mypath/index.cfm") with CFINCLUDE then you must create a mapping for the path using the ColdFusion Administrator. Using relative paths (e.g. TEMPLATE="index.cfm" or TEMPLATE="../index.cfm") does not require the creation of any special mappings. It is therefore recommended that you use relative paths with CFINCLUDE whenever possible.
Please try the following:
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debugging Settings, and select the Robust Exception Information option.
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)
Remote Address 72.40.136.106
Referrer
Date/Time 24-Oct-06 02:48 PM
Referrer
Now I getting the main page but when I hit a section like general or off topic it says not found.
I got on for a few mintutes about 5:30 but nothing was new there and then after I finished running around and doing paperwork around 10 pm main page was there but I couldn't get in
That's because it's in the middle of the night...what the heck Herb, don't you sleep??HandymanHerb wrote:Well i had it for a second, took me two trys to respond to toons post and then it was gone again
2002 Godfrey Marine Sweetwater Challenger 180RE, 60 hp Bigfoot Mercury Mariner 2 stroke oil injected all on a sesame seed bun (LoadRite trailer)
