TOW BAR FOR A PARTY BARGE
ELCATAMARAN
#1 Post by ELCATAMARAN » Fri May 11, 2012 5:37 pm
Hello Guys:
I think this may be helpfull for Sun Tracker Party Barge owners.
I own a 2005 Regency Sun Tracker Party Barge. As the engine is fast enough for skiing and tubing I decided to build a tow bar custom made to fit this pontoon. After I finished the bar, installed it and tested it, I can tell you that it worked great. It is strong enough to pull anything in the water, it does not damage the toon as it is very well fixed with several suports and it does not get on the way of anything on the toon, besides it looks nice!!
I made it myself using a mufler pipe bending machine and had it chromed at a local shop.
Hope it helps some body wondering if they can put a tow bar int their pontoon.
Attached are some pictures of the bar.
This is a view from behind the toon to see how the tow bar clears the top of the ouboard.
This is a view below the toon to see how the tow bar is attached to the cross members.
This is a view from other side of the tow bar already mounted.
This is a view of the tow bar from the side already mounted on the toon.
This is a front view of the tow bar before mounting.
This is a side view of the tow bar before mounting.
ROBERTO
Hello from suny Mexico!!!!
2005 Sun Tracker
Regency Edition
115 Hp Mercury
2006 Hummer H3
Monterrey, Mexico
Woody
Re: TOW BAR FOR A PARTY BARGE
#2 Post by Woody » Fri May 11, 2012 6:11 pm
Good job !! :thumbsup
2019 Veranda 22 RFL 250SHO
Racin929
#3 Post by Racin929 » Fri May 11, 2012 6:55 pm
VERY nice. You should make another and sell it. To me..
2012 Bentley
220 cruise 90hp Merc
Trailered by
1994 F350 CC LB
460 gas (the commuter)
Mrtoler
#4 Post by Mrtoler » Fri May 11, 2012 8:23 pm
Looks great man, that was a great idea to bend the pipe back under the boat to catch several cross members!
2006 dodge ram quad cab
Crosby Texas
#5 Post by badmoonrising » Fri May 11, 2012 9:37 pm
Nice job ! :thumbsup :thumbsup :thumbsup
blackberg
#6 Post by blackberg » Fri May 11, 2012 11:03 pm
that is a great idea :nana
looks great
-bb
fredeboy
#7 Post by fredeboy » Sat May 12, 2012 6:12 am
Looks Nice. How are you attaching the rope to the bar?
gramps
#8 Post by gramps » Sat May 12, 2012 8:17 am
You did a great job and it looks very sturdy.
2012 Berkshire, 230cl Tritoon
150hp Mercury 4stroke
Road King Trailer
Towed with a Buick Enclave
jimrs
#9 Post by jimrs » Sat May 12, 2012 1:21 pm
Wow! That's the most over engineered tow bar I have ever seen. That is the way the other manufactures should build Theirs. Excellent job it should last you the rest of your life.
One question I do have is. How much clearance did you give the rope over the top of the motor. Will the rope rub on the top motor cover?
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
ELCATAMARAN
#10 Post by ELCATAMARAN » Sat May 12, 2012 8:50 pm
Thanks guys for your nice comments, I´m glad you liked the tow bar!!
Racin929: I would love to build one for you but as I live in Mexico it would be complicated to ship it throught the border, besides I believe shiping cost ill be high considering the size and dimentions of the tow bar. Any way, I´ll be posting a picture with the exact measurments so you can have one build for you at any local automotive mufler shop.
Fredeboy: As you may notice, there is ahook at the top of the tow bar where I attach the ski rope with a couple of loops and off we go!!
Besides, the hook is very easy to reach from the back seat of the pontoon.
Jimrs: I made a "prototype" model of the tow bar with PVC pipes and attached it to the toon to do some clearence testing before building the metal tow bar. Afterwards I have done lots of testing with tubes, water ski and several towables and have no clearence problems neither with the motor cover nor anything else so far.
You may notice on the picture I post here with my boy waterskiing, the rope is far away from everything.
Eventually I´ll post a picture with te exact measurments of the tow bar when I go to the lake where I keep my toon.
I´ll be happy to answer any question about the bar.
Cheeers from Mexico!!
Roberto
TESTING THE ROPE CLEARANCE
TESTING THE ROPE CLEARENCE.JPG (135.42 KiB) Viewed 11462 times
ROBERTO
2005 Sun Tracker
Regency Edition
115 Hp Mercury
2006 Hummer H3
Monterrey, Mexico
#11 Post by curtiscapk » Sat May 12, 2012 10:30 pm
Bad Ass!! looks a liittle better than mine.
Drago
#12 Post by Drago » Sun May 13, 2012 5:29 am
That is an awesome job. I normally do not comment just to add a post but again I'll say AWESOME!! Like someone said, the way the boatmakers should do it.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
lx22f/c
#13 Post by lx22f/c » Sun May 13, 2012 7:29 pm
That looks good.
newbie32
#14 Post by newbie32 » Mon May 14, 2012 11:27 am
ELCATAMARAN: we have almost the same boat. I have an 05' suntracker with a 115 merc, 4 stroke. We purchased used a few months ago. If you dont mind me asking, what is your top speed? I see you have a skier on the back. We have only towed a tube at this point because we have only been able to get to 19mph. I think it should have more speed than that. Any info you have would be greatly appreciated. We have a tow bar similar to yours on the back as well.
ELCATAMARAN
#15 Post by ELCATAMARAN » Tue May 15, 2012 7:48 pm
Hi there newbie32: Glad to share the info I got, I should tell you though, that I´m no expert.
Anyway, the top speed I have ever reached is 31 mph with 4 passengers in calm water with no wind and with the bimini top down. With one skier and 2 passengers I´ve got up to 29 mph tops also with the top down. With the top up I loose about 3 mph. All this measurements are with GPS at WOT and using a little bit of trim to get a couple of extra miles and get the engine up to 5,750 RPM.
The difference I see with your engine is that yours is four stroke and mine is two stroke, I don´t really know if this makes a difference in top speed.
Something I would do is check the propeller with an expert at your local marina, maybe you may gain some speed down there and, also a tune up always help.
Hope this info is usefull for you!!
ROBERTO
2005 Sun Tracker
Regency Edition
115 Hp Mercury
2006 Hummer H3
Monterrey, Mexico
