We changed from a 14 x 13p to a 13.75 x15p, it dropped the top RPM from 5800 to 5400 RPM. Pretty much the 400 RPM I was expecting. But now that I got the toon back its time to start working on adding performance/decreasing drag.. You can feel the waves hitting the bottom of the toon when you are sitting up in the seat ahead of the driver (across from the side entry gate, that is almost 3/4 of the way up from the back of the toon) with braces every 16" that is an aweful lot of additional drag from water resistance... I need to speed up my underskinning project...
And I poked my head out over the back, I didn't have my old Sony 5mp with safety strap so I took all these pictures with my phone and since I wasn't too crazy about losing it over the side, I was rather conservative as to how far over I went and how many pictures I took (I have already lost one phone this Spring/Summer)
There seems to be a LOT more water splash coming from the 'driver side' of the toon versus the 'passenger' side
Looking straight down..(that cap on the top of the cover is what the mechanic blamed for getting water into the 2 cycle oil, the seal was missing, you can almost see in these pictures that the cavitation plate is buried way below the water) checking out the passenger side And the 'driver' side (and the ladder is folded up as high as it goes) And one last shot showing the wake.. keep in mind that I am missing the transom splash shields from BOTH sides of the transom, I will be building/welding on new ones soonerish as soon as I decide on a size/shape. Then I will get the guys at work to TIG weld them into place.. (if anybody happens to have a similar age South Bay pontoon and would be willing to take some measurements that would be awesome)
-ron
