Ruined tires!
captainjack
Ruined tires!
Well the past 2 weekends when I get to my boat I have had a ruined tire by crap in the road! I am sick of dealing with flats making it's 2 pm before I am on the water! Then I get to buy a tire this sucks an having 60% tread left. I hope this week is different! Hope everyone is enjoying there time on the water this summer the weather has been great for it at least in my area!
2008 Playcraft Extreme 2600
2008 300 Mercury Verado
2008 Bear Trailer
Iowa
2008 Bear Trailer
Iowa
- STEVEBRENDA
Re: Ruined tires!
Sorry for your misfortune but -----Bear Trailer
Nothing but trouble with my Bear trailer. 60% treadleft? In theory a tire should never wear out, but they usually dry rot. If yours has been out in the sun for 4 years, you probably were due for new tires.
2014 Regency 254
Mercury 250L Verado
Mercury 250L Verado
Re: Ruined tires!
Often overlooked is that when you get a flat on a dual-axle trailer the remaining tire is overloaded & should also be replaced. Could be a factor if you are having problems on the same side...
Mark
Rush Lake, Atlanta, MI
Re: Ruined tires!
I've never had tires wear out on any boat I've owned. Dry rot, yes...
Re: Ruined tires!
- rancherlee
Re: Ruined tires!
guy48065 wrote:Often overlooked is that when you get a flat on a dual-axle trailer the remaining tire is overloaded & should also be replaced. Could be a factor if you are having problems on the same side...
Which is why all my play toy trailers have axle/tire combos that can handle the load on there own. When I built my pontoon trailer the difference in price between 3800# rated pair vs 7500# rated pair was 160$ (40$ per axle, and 20$ per tire). For that 160$ difference the tires/axles are only at 50% capacity instead of near 100% and IF I get flat on a busy highway, road with a small shoulder it only takes me 30 seconds to run back and use a ratchet strap to lift flat up in the air and continue driving to a safe place. Even better if a wheel bearing goes south. I will NEVER own a trailer with 2+ torsion axles either as the load is never shared 50/50 between the axles like a properly setup leaf/equalizer will.
captainjack
Re: Ruined tires!
Yeah bear won't do that again 2500 upgrade from the shorelander when it should have been half the price of a shorelander they are half the quality! Ha ha week one rebar week 2 a piece of angle iron an no dry rot as of yet but maybe this week! Who knows but I am getting there at 8 sat morning this week gonna get my tire changing done early an enjoy the day!
2008 Bear Trailer
Iowa
2008 Bear Trailer
Iowa
- The_Hellbilly
Re: Ruined tires!
If it makes ya feel better I got into some honeylocust thorns while brush hogging last week with my tractor & ruined a front tire, a $750 front tire
2005 Voyager 22ft Tritoon
2004 Honda 135hp
2004 Honda 135hp
spurhunter
Re: Ruined tires!
I hear ya. I am burning through a front tire on my tandem about every 20 trips to the lake. I assume its a bad axle, its not the bearing, checked those. Im lucky a buddy is in the trailer biz and I get new tire/wheel combos for $25 from him.
1985 Johnson 175 gas guzzler
2007 2500HD Duramax Z71
captainjack
Re: Ruined tires!
Yep roland I feel ur pain! Wow glad I am not into tractors! I thought 42 a tire was ok but ya got me smoked at 25 that's an awesome deal!
2008 Bear Trailer
Iowa
2008 Bear Trailer
Iowa
Re: Ruined tires!
I can commiserate. I have a Bear trailer. My rear tires went bald very quickly. The fronts have great tread. The rears are the ones with brakes on them, and I don't' know if that matters or not. I had a guy tell me that when I make turns, one tire on each side becomes a pivot and the other one is pretty much slid sideways against the tread.
I don't know. All I know is I have to buy two new tires before we take the boat out again.
Kevin
Kevin
2010 G3 SunCatcher LX22FC w/ Yamaha F115
- STEVEBRENDA
Re: Ruined tires!
Check to make sure you don't have a bent axle, thta can be a very likely cuse.I hear ya. I am burning through a front tire on my tandem about every 20 trips to the lake. I assume its a bad axle, its not the bearing, checked those. Im lucky a buddy is in the trailer biz and I get new tire/wheel combos for $25 from him.
2014 Regency 254
Mercury 250L Verado
Mercury 250L Verado
Re: Ruined tires!
maybe your overloaded with the BIG ASS 300 Merc on the back
Shopguy
Strakes and skins
Strakes and skins
Re: Ruined tires!
Your friend is correct...I have a triple axle trailer and the boat shop tried to turn the trailer too sharply on a smooth concrete floor and pulled a front tire sideways right off the rim! i love these guys!!ksmith wrote:. I had a guy tell me that when I make turns, one tire on each side becomes a pivot and the other one is pretty much slid sideways against the tread.
Kevin
playcat
JC 266 TriToon
Kerr Reservoir, VA
JC 266 TriToon
Kerr Reservoir, VA
