Tritoon Underskin question...
rbiederwolf
#1 Post by rbiederwolf » Sun Jul 29, 2012 2:45 pm
I want to underskin my tritoon. However I have some concerns/questions. Tritoon does not have a lot of exposed underneath area, however it definitely gets "grabbed" by the waves..
I boat in salt water, and I am afraid of sealing up the underneath, to the point that I won't be able to flush the salt away after boating. I know salt water will find its way through the underskinning. Thus I was thinking that just skinning the majority of the exposed beams between the toons, but leaving say a inch or so from each side, then I could still have some area to be able to get a hose in for flushing. I would think that this would stop most of the wave/crossmember interaction. Albeit not the perfect solution.
I know I could install skin with screws and remove them from time to time, but this is alot of added work I do not really want.
What does anyone think???? I am just paranoid
2008 Yamaha 150hp
NH Tooner
Re: Tritoon Underskin question...
#2 Post by NH Tooner » Sun Jul 29, 2012 3:02 pm
I think your concerns are justified. Here is an idea I thought of once. Run a 1/2 hose or pvc down the center of each bay and install spray nozzles between each crossmember with a garden hose fitting at each end. Skin over that. when you are done in salt water just attach you garden hose and let the spray heads do the work. I thought of using the small spray heads used for irrigation lines.
Dave
2012 Homebuilt 28' Tritoon
225 hp Mercury
1993 24' Forester
50 hp mercury
gramps
#3 Post by gramps » Sun Jul 29, 2012 4:49 pm
I think your idea sounds good to me and see no reason why it won't work.
2012 Berkshire, 230cl Tritoon
150hp Mercury 4stroke
Road King Trailer
Towed with a Buick Enclave
cwag911
#4 Post by cwag911 » Sun Jul 29, 2012 5:01 pm
Even with the skin on you'll be able to get a hose in from the side, between the deck and the tubes.
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
#5 Post by Bamaman » Sun Jul 29, 2012 5:22 pm
See what kind of stainless sheet metal screws you can purchase in bulk at a fastner place like Fastenal. (Forget Home Depot or Lowes.) Rivets would be nice, but it's hard holding up sheeting while drilling holes--so you can use the rivet gun. And it takes twice as many rivets as screws to do the same job.
Go to a boat dealership and look at how factories have installed their sheeting. Since the middle toon was added, you shouldn't have to buy too much sheet aluminum. I'd also use the same thickness as manufacturers use.
The above suggestions are also good as how to flush out the cavities.
NH Tooner
#6 Post by NH Tooner » Sun Jul 29, 2012 6:12 pm
cwag911 wrote:Even with the skin on you'll be able to get a hose in from the side, between the deck and the tubes.
There is no way on mine to get in from the side as the uprights on the tubes are solid one piece the whole length of the tubes.
Dave
225 hp Mercury
1993 24' Forester
50 hp mercury
rbiederwolf
#7 Post by rbiederwolf » Mon Jul 30, 2012 6:54 am
NH Tooner wrote:I think your concerns are justified. Here is an idea I thought of once. Run a 1/2 hose or pvc down the center of each bay and install spray nozzles between each crossmember with a garden hose fitting at each end. Skin over that. when you are done in salt water just attach you garden hose and let the spray heads do the work. I thought of using the small spray heads used for irrigation lines.
Do you mean from side to side???
2008 Yamaha 150hp
ronb
#8 Post by ronb » Mon Jul 30, 2012 7:02 am
Not much to add, mostly just following along. However here is a picture of the bottom of a tri-toon Sun Tracker that I took a couple weeks ago. I had more but somehow 'lost' the phone that I took them with.. (I left it on the front deck of the pontoon as I drove down the highway.... :oops: )
If you click on these youc an see more 'full sized' pictures (I guess I was smrt enough to upload them to Photobucket before losing my phone!)
From what I've read on here, I see many fewer rivets than the 'do it yourself guys' are using..
-ron
2007 South Bay 922CR
Mercury 90hp Optimax
Fargo, ND
#9 Post by Bryden24shp » Mon Jul 30, 2012 7:50 am
Can you cut a hole in the underskinning, between stringers, big enough to get a spray head into and spray around 360 degree's, then just cut a square plate to cover the hole and use 4 aluminum (soft) rivets to hold the covers in place. Then you can just drill 3 rivets out, slide the plate around and rinse. Slide the plate back over the hole and re-rivet.
Just a thought???
Shopguy
#10 Post by Shopguy » Mon Jul 30, 2012 9:37 am
Mine has about an inch down both sides and seems to work fine.... just sayin
Shopguy
Strakes and skins
NH Tooner
#11 Post by NH Tooner » Mon Jul 30, 2012 5:51 pm
I would run 2 hoses down the center front to back between the toons. Might run one on each of the outer sides too..
Dave
225 hp Mercury
1993 24' Forester
50 hp mercury
NH Tooner
#12 Post by NH Tooner » Mon Jul 30, 2012 5:54 pm
Bryden24shp wrote:Can you cut a hole in the underskinning, between stringers, big enough to get a spray head into and spray around 360 degree's, then just cut a square plate to cover the hole and use 4 aluminum (soft) rivets to hold the covers in place. Then you can just drill 3 rivets out, slide the plate around and rinse. Slide the plate back over the hole and re-rivet.
Just a thought???
I not sure but I'm thinking he is looking for a way to clean it quite ofter.
Dave
225 hp Mercury
1993 24' Forester
50 hp mercury
