Last Friday I rushed home immediately after work because a storm was coming (70mph straight line winds, strong wind, chance of hail... we got some marble sized). In my haste, I neglected to pay attention to the gas gauge. So this morning I head out to get my stuff in the pickup, fire it up, and low and behold its on the red! I can't make it in to town without adding some gas, no problem, grab the lawnmower gas can (empty, grr). Then I realized I have about 20 gallons sitting on the boat, but how to get 5 gallons into the pickup? I thought about siphoning, no hose. I thought gravity would work through the factory fuel line to siphon, no luck there is a 1 way spring loaded check valve threaded into the top of the fuel tank making it 'spill proof'. Then it struck me! I had a spare 12v fuel pump from a car project just sitting on my shelf! So here you have the rigging..
1 3/8" electric fuel pump
1 set of el-cheapo jumper cables
4ft of 5/8" heater hose (the only hose I could find this morning, I would have sworn I had some high pressure 3/8" fuel line but couldn't find it)
2ft of black duct tape
This winter I will use this setup with 3/8" hose, but I will probably pump it into the tractor..
So what about the rest of you? Do you just run it empty or do you have your own process for emptying the tank?
And if you ever need stories of stupidity to brighten your day.. let me know, I am full of 'life experiences'
-ron
