FM Radio Reception
PeaceRiverRider
FM Radio Reception
#1 Post by PeaceRiverRider » Sat Aug 18, 2012 7:14 am
I am looking to replace my head unit and would like to get one with a good FM tuner. Is there a way to tell which units my have better FM reception.
1996 22' Crest II Pontoon Boat
2008 90hp Mercury 4 Stroke
Punta Gorda, FL
jimrs
Re: FM Radio Reception
#2 Post by jimrs » Sat Aug 18, 2012 7:46 am
The ones with the best antennas. Where do you boat? How far from the towers?
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
Drago
#3 Post by Drago » Sat Aug 18, 2012 8:52 am
I think most marine radio specs are nearly the same for FM reception so it might not matter in that regard. I ran a simple dipole antenna under the helm that works good. If you want fancy, try
http://www.wholesalemarine.com/p/DUA-MA ... A_d_MAR16W
or
http://www.amazon.com/dp/B000XBBJMO/ref ... B000XBBJMO
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
PeaceRiverRider
#4 Post by PeaceRiverRider » Sat Aug 18, 2012 11:19 am
I actually have a good antenna (Shakespeare 4350). I have an older Maxxima by Panor Model CSC-737CD stereo system. (I also have the cassette version which I can just pull out and put the CD one in and there seems to be no difference) I've been out with others and had the same radio station on and theirs would come in fine and mine would fade in and out or just not come in. That's why I thought it may be the unit.
Thanks for all your replies.
Punta Gorda, FL
GregF
#5 Post by GregF » Sat Aug 18, 2012 1:06 pm
I suspect radio technology is pretty much the same. They probably all use the same chip set.
You big difference will be the antenna you choose. I would invest in a good high gain antenna if I lived in a fringe area.
(bottom of a valley or 100 miles from the station.)
1974 Harris
70 HP 4 stroke EFI Yamaha
screwball
#6 Post by screwball » Sat Aug 18, 2012 2:21 pm
FM is kind of a short range radio, usually 50 mile radius of the transmitter. A REALLY good antenna might get you a few more miles. Unlike AM radio it won't 'skip' off the troposphere, and there aren't any 'clear channels'. I'm not a "Top 40 Radio" kind of a guy so I broke down and bought a second XM radio receiver for the boat. I think the second receiver is 6 bucks a month or something like that. Well worth it to me.
Good Luck
We are really Steve and Vesta Brown
2012 Sun Tracker 18' Party Barge w/ 75hp Merc.
A pair of 2011 Seadoo GTI-SE PWC's
2 Harley Davidson Tri-Glides '09 mine, '11 hers
[s]A couple of Polaris 500 Scrambler Quads[/s]
We take our recreation VERY seriously
Capt Sully
#7 Post by Capt Sully » Sat Aug 18, 2012 6:46 pm
I have the same problem, FM signal is very weak. I have XM radio mobile setup so I just pull it from the truck and plug it in the boat. tune my FM boat radio to 88.3 and it receives the XM signal just fine, everywhere I go.
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
GregF
#8 Post by GregF » Sat Aug 18, 2012 7:26 pm
screwball wrote:FM is kind of a short range radio, usually 50 mile radius of the transmitter. A REALLY good antenna might get you a few more miles. Unlike AM radio it won't 'skip' off the troposphere, and there aren't any 'clear channels'. I'm not a "Top 40 Radio" kind of a guy so I broke down and bought a second XM radio receiver for the boat. I think the second receiver is 6 bucks a month or something like that. Well worth it to me.
Good Luck
I can get the radio station out of the Keys if the conditions are right and that is close to 100 miles but is over water.
1974 Harris
waterlab
#9 Post by waterlab » Sun Aug 19, 2012 6:38 am
Capt Sully wrote:I have the same problem, FM signal is very weak. I have XM radio mobile setup so I just pull it from the truck and plug it in the boat. tune my FM boat radio to 88.3 and it receives the XM signal just fine, everywhere I go.
Do the same as you and it's the only way to go, and its good to have other stuff to listen to than just music
OK Toon
#10 Post by OK Toon » Mon Aug 20, 2012 7:00 am
There are a couple of lakes we go to where we get no radio reception at all. Our stereo does not have an MP3 input on it so we use an FM Transmitter on our iPod -- set the radio to an off-station and set the iPod FM transmitter to the same station -- and we then we have tunes on the toon.
This way we can have our "boat music" play list.
