What ideas for pontoon rests?
For winter storage what does everyone like to place their tubes on? I see cinder blocks in use around my lake and the price is right--but that seems a little harsh & unstable for resting a round thin aluminum tube on. Some sort of stand with a nylon sling would be ideal if such a thing exists.
Mark
Rush Lake, Atlanta, MI
Re: What ideas for pontoon rests?
Typical here is concrete blocks with a 2x8 on top.
Getting them level is the trick, use a string line and the blocks go "holes up"
1974 Harris
70 HP 4 stroke EFI Yamaha
I have mine sitting on 4 6"x6"x6'.
What is this "winter" you speak of?
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
2016 Chevy Tahoe
2009 GMC Sierra
BoatCop wrote:What is this "winter" you speak of?
If I ever get to AZ you can arrest me.
Nothing is level on the lakefrontGregF wrote:Typical here is concrete blocks with a 2x8 on top.
With a bit of shovel work I could probably achieve L-R level but F-R will be on a gentle slope (sloped from the street right to the water's edge).
In line and on either side of the tubes--or cross-ways?mgarvie wrote:I have mine sitting on 4 6"x6"x6'.
Mark
I've seen online plastic pods (set of 4) that resemble a stepstool but $90 for a set of contoured buckets seems a little steep.
Mark
Mine sits on the trailer for four months.
A thought--What about setting it down on 4 old tires? Enough "squish" to conform to the radius of the tubes, won't scratch, won't dent, won't slide, costs nothing.
Mark
I have seen lots of pontoons locally that sign on tires for extended periods.
-ron
-ron
My marina guy says that anything hard is a total no-no. Unless you have the rests PERFECTLY aligned, you put unequal stresses on your tubes. He has seen them bent that way.
He never sets a boat down on anything other than old tires, which are strong, but have enough give to equalize the weight.
I've seen them on many dealership lots sitting on big styrofoam chunks--ex-floating dock floatation. They're about 2-3 feet off the ground that way, and styrofoam doesn't scratch the toons.
