Rough water trailer guides, installed
#1 Post by Bryden24shp » Fri Sep 07, 2012 11:12 am
Just bought these from Overtons. Had to make shackles to fit the trailer, they came with 2X4 square bolts that wouldn't fit, of course. My trailer frame is 2X4. So I just custom made 4 lower brackets and used 8 1/2x6" bolts. I left about 1/4" on the sides and the top of them clear the underskinning by about 2 inches. Installation time was 1/2 BudLight with an air impact. Should work good in the Mississippi current and in strong gusts of wind... I hope!
http://www.overtons.com/modperl/product ... rchID=4006
Thought you might like to see them!
guides 004.jpg (103.3 KiB) Viewed 5259 times
guides 003.jpg (111.77 KiB) Viewed 5257 times
guides 002.jpg (117.16 KiB) Viewed 5258 times
guides 001.jpg (116.87 KiB) Viewed 5257 times
bstat1020
Re: Rough water trailer guides, installed
#2 Post by bstat1020 » Fri Sep 07, 2012 11:17 am
1/2 of a bud light?
It only took you 30 seconds to put those on?! :lol3
2011 Harris Flote Bote Cruiser 20CX with 60hp EFI Bigfoot
#3 Post by Bryden24shp » Fri Sep 07, 2012 11:57 am
bstat1020 wrote:1/2 of a bud light?
I thought that was too long! :donno
dockholiday
#4 Post by dockholiday » Fri Sep 07, 2012 1:27 pm
hope you didn't have to pay for that merc cover. can't remember price but seem like they were high dollar. almost like the set of cowl decals I priced once.
#5 Post by Bryden24shp » Fri Sep 07, 2012 1:50 pm
Nope, stole it off a Bass boat sittin in the Holiday Inn parking lot. You think Il'd pay Bass Pro Shops $196.00 plus $12.85 shipping for one! Ok, I did!
Only the best for my boats! Mac&Cheese for dinner and 2 year old sneakers, is all I need. But when it comes to the boat...
:bowdown
Woody
#6 Post by Woody » Fri Sep 07, 2012 2:34 pm
I have the same set, but I had to shorten mine. They work very well.
2019 Veranda 22 RFL 250SHO
tuned
#7 Post by tuned » Fri Sep 07, 2012 3:04 pm
That may have been a typo. Im thinking that the line between the 1 and the 2 should not be there :drink4
#8 Post by Bryden24shp » Sat Sep 08, 2012 5:04 am
That was at 8:30 am. Just getting the primer loaded!
#9 Post by ROLAND » Sun Sep 09, 2012 12:04 am
bryden, check your pm.... I sent you one about a week ago....
wrakoski
#10 Post by wrakoski » Sun Sep 09, 2012 3:48 am
Nice....
I may do the same, not necessarily for rough water but to help getting the arse end of the boat straight on the trailer. It seems so much harder with the 36" PTX than it was with my old 2 toon.
#11 Post by Bryden24shp » Sun Sep 09, 2012 9:03 am
wrakoski wrote:Nice....
Exactly! That flat bottom wanders all over, doesn't it! Going out today, will let ya know how it works!
#12 Post by Bryden24shp » Sun Sep 09, 2012 9:09 am
ROLAND wrote:bryden, check your pm.... I sent you one about a week ago....
I though I responded to it, I hit save instead of send! PM is replied to now!
Thanks Roland!
#13 Post by Bryden24shp » Sun Sep 09, 2012 4:45 pm
They worked great. had a about a 15 mph cross wind, got me a litle crooked lining up the front of the bunks. Gave the boat alittle starboard wheel and let the guides line it up. it straightened out perfect. Denise winched it up to the trailer stops and pulled it out. Straight as an arrow. No rockin it over to center.
I'm sold!
IrnGynt
#14 Post by IrnGynt » Mon Sep 10, 2012 5:38 am
I was going to get a set of those but went with rollers instead. Not so much as to help me guide onto the trailer but to keep the rear end straight as I motor up to the bump stop. The rollers were useless for that. They just flex. Out of countless loadings, I've had to winch up at least half way every time because the back end will not stay straight.
Are those pretty solid? I was a little worried about those marring the tunes.
2012 Bass Buggy 18
60hp Mercury Bigfoot
Northern VA
Occoquan/Lake Gaston/Lake Anna
#15 Post by Bryden24shp » Mon Sep 10, 2012 6:29 am
Very solid. I looked last night after I loaded it, just to check. I was worried about the black PVC covers leaving black marks. No marks at all from them. Nothin at all. But that was the first time with them on, too. As time passes, I can tell you better. Denise backed the trailer in until about 2 foot the front of the bunks were out of the water. The back guides were probably 8" out. It made it real easy, in the wind. Probably won't be able to see the guides when at the Lake of the Ozarks. The State Park Boat Ramp in Osage Beach is really steep, so it may be a bit more of a challenge.
