can it be this drastic?
Pontoon Really?
I have a Sylvan RPT 8522 with a 150 Optimax. The boat has run great all year. I hane not used it in about a month. I could only top out at 28 mph. I usually run around 40 - 42 MPH.
Could the growth on the tunes slow me down that much?
Thanks in advance!!
Thanks in advance!!
Re: can it be this drastic?
What RPMs are you pulling, compared to prior runs?
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
2016 Chevy Tahoe
2009 GMC Sierra
What do the toons look like? If they are encrusted, it can easily rob that much speed.
1974 Harris
70 HP 4 stroke EFI Yamaha
Yes. Are you running in salt water? Is your bottom painted? As Greg asked, how does your bottom look? A few barnacles on your prop can cause huge losses.Pontoon Really? wrote:I have a Sylvan RPT 8522 with a 150 Optimax. The boat has run great all year. I hane not used it in about a month. I could only top out at 28 mph. I usually run around 40 - 42 MPH.
Thanks in advance!!
2007, 2570 Crest LE II
Yamaha F150
Yamaha F150
I don't know about salt water but I would say no in freshwater. We let our boat sit for a few weeks if we are traveling and when we use it I really don't see any difference.Pontoon Really? wrote:I have a Sylvan RPT 8522 with a 150 Optimax. The boat has run great all year. I hane not used it in about a month. I could only top out at 28 mph. I usually run around 40 - 42 MPH.
Thanks in advance!!
2012 Berkshire, 230cl Tritoon
150hp Mercury 4stroke
Road King Trailer
Towed with a Buick Enclave
Road King Trailer
sounds more like bad fuel to me. Were you using non ethanol gas?????
Wayne and Carla Taylor
Vanvouver, WA.
2005 Suntracker Bass Buggy
54# Motorguide trolling motor
2 Hummingbird Fish Finders
03 Dodge Ram 1500 2wd
Vanvouver, WA.
- Texoma Toon
Check your fuel filter too!
2007 G3 LX 22 Fish & Cruise
90 Hp Yammy
Dual Axle Trailer
90 Hp Yammy
Dual Axle Trailer
Algae growth slows our tritoon down 6-9 mph. after I scrape the algae off with a plastic paint scraper we gain 6-9 mph.
- The_Hellbilly
Could be a leak in a log and now your toon is ALOT heavier. It happened to me.
2005 Voyager 22ft Tritoon
2004 Honda 135hp
2004 Honda 135hp
Pontoon Really?
I am running 4800 RPM WOT. I have only lost 200 RPM. I did not think about the fuel - quite possible.BoatCop wrote:What RPMs are you pulling, compared to prior runs?
The logs are all scummed up......fresh water - dirty lake. I will have the tunes checked for leaks when I pull her out later this month.
Thanks to all!!
I keep my boat in the water (fresh) from March thru October. In Louisiana (think hot water), I have to scrape my toons at least 3 times a year and as I approach toon scraping time, I bet I lose close to 10mph in top end speed because of the growth. The boat performs like a PIG with all that growth on there.
- Texoma Toon
4800 rpm is less than it should at wot. Shouldn't it be closer to 5500-6000? You may want to check your tac or your prop is not right for your toon......Pontoon Really? wrote:I am running 4800 RPM WOT. I have only lost 200 RPM. I did not think about the fuel - quite possible.BoatCop wrote:What RPMs are you pulling, compared to prior runs?
Thanks to all!!
90 Hp Yammy
Dual Axle Trailer
90 Hp Yammy
Dual Axle Trailer
