TOON CLEANERS
ROBBSRACINGENGINES
Re: TOON CLEANERS
#16 Post by ROBBSRACINGENGINES » Thu Sep 27, 2012 6:04 am
I would imagine it has been mentioned here many times before. Pink coil cleaner is the easiest, cheapest and quickest way to clean them toons. I put it in a pump sprayer. Spray 1 half of a tube at a time. Let it sit for 2-3 minutes then just hose it off. No scrubbing nothing. works like a charm.
IMAG0282 (Medium).jpg (94.24 KiB) Viewed 10534 times
rwtdct
Re: TOON CLEANERS
#17 Post by rwtdct » Thu Sep 27, 2012 12:57 pm
Will eather of these cleaners damage the paint on the boat trailer? When I clean my toons the boat will be on the trailer.
Does anyone have the answer?
2007 Suntracker Rengency Limited Party Barge 25ft 135HP
Central Coast Calif.
There is one thing that is for sure. That there will always be change.
D.L.
Re: TOON CLEANERS
#18 Post by D.L. » Thu Sep 27, 2012 1:03 pm
From what Ive heard no. I'll be trying it in a few weeks.
2016 Harris Solstice 240 DLCB
Mercury Verado 200
ROBBSRACINGENGINES
Re: TOON CLEANERS
#19 Post by ROBBSRACINGENGINES » Thu Sep 27, 2012 6:51 pm
My curent toon sits on a galvanized trailer and my last one on a painted trailer. I have used the pink stuff on both and never had any trouble with it damaging anything on either of them.
D.L.
Re: TOON CLEANERS
#20 Post by D.L. » Tue Oct 09, 2012 11:59 am
I cleaned mine with the NAPA cleaner this weekend and its a night and day difference. Sprayed it on with a pump sprayer let it sit about 30 seconds and wash off VERY good. No problems with trailer.
Mercury Verado 200
dockholiday
Re: TOON CLEANERS
#21 Post by dockholiday » Tue Oct 09, 2012 12:43 pm
rwtdct wrote:Will eather of these cleaners damage the paint on the boat trailer? When I clean my toons the boat will be on the trailer.
Have not used the coil cleaner but used a lot of diff thing over the years that was plenty strong with no damage or streaking. I always wet the trailer well so if an when the cleaner hits it at least it will be diluted by the water. Seem to have worked so far.
OK Toon
Re: TOON CLEANERS
#22 Post by OK Toon » Tue Oct 09, 2012 1:03 pm
D.L. wrote:I cleaned mine with the NAPA cleaner this weekend and its a night and day difference. Sprayed it on with a pump sprayer let it sit about 30 seconds and wash off VERY good. No problems with trailer.
Would love to see pics of the cleaned toons. Actually, some "before" and "after" would be great. Did you like the final finish with just using the NAPA cleaner? I haven't done mine yet but will also be getting some Sharkhide to protect the finish on the toons after they are cleaned - this is on my winter list of projects to do.
old jim
Re: TOON CLEANERS
#23 Post by old jim » Wed Oct 10, 2012 6:50 pm
So I used the Napa Alum. Brightener yesterday. I am happy with the end results, toons look
much better. I think wetting the surface before spraying is the way to go. bought 2 spray
bottles 10 bucks each, gallon was 27 bucks locally. Used all of one bottle and a little bit of the second jug. I only did the exterior sides and the cones. Would have needed some sort
of breathing appratus if I had gotten under the boat. It is on the trailer. Rinsed as I went
along. Regards, old jim
guy48065
Re: TOON CLEANERS
#24 Post by guy48065 » Thu Oct 11, 2012 9:13 am
I reviewed the MSDS sheets for both products and both contain hydrofluoric acid & phosphoric acid as the main ingredients. Both companies are vague as to the actual concentrations so I have no idea if one might work faster but I'll bet the results are the same. Buy which ever one you can find.
IMO you will get some streaking of the paint on a trailer if this stuff hits it undiluted. These solutions come in poly jugs so it *might* not harm synthetic carpet but I would generously rinse carpets & bunks just to be safe.
Mark
Rush Lake, Atlanta, MI
bstat1020
Re: TOON CLEANERS
#25 Post by bstat1020 » Tue Oct 23, 2012 1:16 pm
So is everyone using Sharkhide after cleaning their toons with NAPA cleaner?
I would think that if you do not the toons will be black again after a couple of trips in the water.
2011 Harris Flote Bote Cruiser 20CX with 60hp EFI Bigfoot
Traillblazer
Re: TOON CLEANERS
#26 Post by Traillblazer » Tue Oct 23, 2012 1:46 pm
Mine came out nice, but not perfect, and its only 3 months old. They oxidize up real fast. I did one side and need to finish the other. I will try to remember to get some pics
Re: TOON CLEANERS
#27 Post by Bamaman » Tue Oct 23, 2012 6:53 pm
The toons of my new Bennington were tarnished after 4 months, but not actually dirty.
I went after them with White Diamond metal/aluminum polish, available @ Advance, and a Porter Cable Dual Action buffer with a 6" wool polishing bonnet. The Mothers' mag/aluminum polish I bought was simply a junk product--no comparison.
After much experimenting, I found 3 dime size squirts would polish 2'x2' section. It went on black, turned to light gray, and eventually buffed off when it dried--after a minute or so. The really good polishing comes right before the powder blows off. Then I wiped down the area with a rag to remove the black aluminum oxide.
After two polishing applications and some spot polishing, the boat really looked great. Today, I put the Sharkhide on the rear of the boat--only to have black swirls go into the Sharkhide. Now, I've got to wipe the boat down a few times with lacquer cleaner to get every big of black oxide off it. I think the wipe downs will be a long, drawn out process.
Nothing worthwhile seems like it comes easy in marine detailing.
dockholiday
Re: TOON CLEANERS
#28 Post by dockholiday » Tue Oct 23, 2012 9:46 pm
bama what didn't you like about the mothers? It worked pretty well for me about even with the meguiars.
fishinnut
Re: TOON CLEANERS
#29 Post by fishinnut » Thu Oct 25, 2012 10:22 pm
Anyone ever try JJV's Best Aluminum cleaner? Saw some good reviews about it.
lounge lizard
Re: TOON CLEANERS
#30 Post by lounge lizard » Fri Nov 16, 2012 7:44 pm
Reviving the dead here. Im looking for the most common way people use the Napa aluminum brightener. Straight or diluted? Idf diluted, how much? I read one post that said 3 to 1. Thanks, Frank.
99 Voyager 21' fish n cruise /Merc 115
Duramax/Lance 835
KTM/Honda/Polaris
Motorized advocate in Colo. CMTRA, our local club.
www.cmtrail.org come visit!
