any VHF radio geeks out there??
- brianD
- Location: Live in STL, Boat wherever there's enough water to not mess up a prop.
So i broke my vhf antenna and need to replace it. i have a st andard horizon vhf with ais. I'm looking at the Shakespeare 5226-xt antenna as a replacement. I know it wilk have to much coax. What are my options?
If i coil it won't that create an inductive loop?
If i cut it won't that mess with the SWR??
am i over thinking this??
b
2006 Landau Excalibur 2700
225 Suzuki 4 stroke
2011 Bear tandem trailer
2011 3/4 ton Suburban
225 Suzuki 4 stroke
Re: any VHF radio geeks out there??
Think you have it on your own answer. Have had many vhf radios down thru the years. In my humble opinion, it makes no difference if you coil the cable or cut it off. I have done it both ways and prefer to coil it because you never know if you will use it on a different boat down the line. A word of caution, try to stay away from the compass, it will drive it nuts.
- Capt Sully
it will be ok to coil it, be carefull not to kink it, I would roll it in about 4'' roll.
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
FVC USCG Auxiliary
Vietnam 66 / 67
- brianD
Great ! I appreciate the help. I will coil it and tuck it away.
For future reference, when pulling into a strange slip. Fiberglass doesn't beat steel for strength.
b
225 Suzuki 4 stroke
225 Suzuki 4 stroke
The power loss in an extra 10' of coax at 160MHz won't bother you a bit. If you've got an extra 50', I'd consider re-terminating it.
1984 Riviera Cruiser 28ft, rebuilt and enhanced with 175hp Evinrude
