First time putting up the '79 Crest for the winter. The boat sits on 4 old tires beside the cottage with the scissor-lift trailer tucked underneath. The just-bought cottage had 2 blue poly tarps in the shed I assumed were for the boat. I lowered the canopy & draped the tarps over & tied off the grommets with the lengths of para cord that were attached. There didn't seem to be enough ropes & I'm not sure how that tarp is going to do over the winter with snow piled up on it. I have a hunch it's already blown off in the high winds brought by Sandy :-/
Some questions I have, and a plea for other tips:
Should I leave the canopy on the frame or remove it? It's a 70's flat-top canopy frame and folds down to rest on the railing.
Should I rig up some sort of ridge pole so some of the snow slides off? Ideas would be appreciated
Would it be better to hang weights from the grommets rather than tie off to the logs? Thinking water-filled milk jugs...like I used to do with my pool.
And no I won't be shrink-wrapping it or buying an expensive custom cover. I'm about broke renovating the cottage.
