Need to drill a couple of holes
RJF
#1 Post by RJF » Sun Jan 13, 2013 9:11 am
In the side panels of my new 'toon. Mounting a rod holder. Looks like I need a 1/4 inch or a bit less in diameter. I've had thin sheet metal tear when drilling into it. Anything I need to know, before I start? :?:
2013 Aqua Patio - 90 hp Honda. Retired, living on Houghton Lake, MI.
Ray Jr.
Re: Need to drill a couple of holes
#2 Post by Ray Jr. » Sun Jan 13, 2013 9:14 am
These are perfect for drilling sheet metal, especially thin aluminum
http://www.lowes.com/ProductDisplay?par ... &cId=PDIO1
2010 150 HP Mercury Optimax
cwag911
#3 Post by cwag911 » Sun Jan 13, 2013 10:18 am
+1 on the Unibit.
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
bobalong
#4 Post by bobalong » Sun Jan 13, 2013 1:13 pm
RJF wrote:In the side panels of my new 'toon. Mounting a rod holder. Looks like I need a 1/4 inch or a bit less in diameter. I've had thin sheet metal tear when drilling into it. Anything I need to know, before I start? :?:
Is there a reason why you are mounting to the panel rather than the railing?
2011 Sweetwater 206F Sunrise
2011 60 HP Evinrude Etec
Humminbird 798SiHd
Boating on Moose, Pigeon, Lac St. Anne and Sask Landing
cbavier
#5 Post by cbavier » Sun Jan 13, 2013 2:05 pm
On mine I had the holders that bolted to the square rails. I didn't have to drill any holes and it let me move the rod holders to anywhere I wanted to move them. It's much better than drilling any holes. Mine came from Cabella's. $25 each
Own-It-II
Chuck
50 HP Johnson
06 GMC Sierra Crew Cab
Roscommon, MI
Capt Sully
#6 Post by Capt Sully » Sun Jan 13, 2013 2:47 pm
use a center punch and a sharp bit, start slow
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
#7 Post by badmoonrising » Sun Jan 13, 2013 11:51 pm
cwag911 wrote:+1 on the Unibit.
+2 :thumbsup
bodie
#8 Post by bodie » Mon Jan 14, 2013 2:57 am
+1 on the bolt ons for the rails. I get my Cabela here in Ohio March 7th (taking the day from work lol). Thats going to be one of my 1st purchases...
B.S.BARge
Bodie & Stefanie
Central Ohio Lakes
2007 Chevy Sliverado Z71
#9 Post by Bryden24shp » Mon Jan 14, 2013 8:13 am
+2 :thumbsup
+3, I use them on all my thin wall aluminum projects. Really work good for drilling the holes into underskinning goes super fast!
RonKMiller
#10 Post by RonKMiller » Tue Jan 15, 2013 9:53 am
Step drills are awesome, and you can get a 3 piece set at Horrible Freight for $12.99:
http://www.harborfreight.com/3-piece-ti ... 91616.html
Once you've used them you'll wonder how you ever lived without them... :bowdown
#11 Post by Bryden24shp » Tue Jan 15, 2013 11:09 am
RonKMiller wrote:Step drills are awesome, and you can get a 3 piece set at Horrible Freight for $12.99:
:lol: Horrible Freight!
RJF
#12 Post by RJF » Wed Jan 16, 2013 7:25 pm
Thanks for the lead. I thought I had every tool in the World, and two of most of them. Never seen this drill before. I'm using the Cabela's mounts. On the starboard side, no problem - mounted it on the door. On port side, there is no door and no spot without the panel below the rail. Two holes is the only way I can think of to mount it.
640 X 480.jpg (252.74 KiB) Viewed 2924 times
