leaking toon???
bentleyjc
leaking toon???
#1 Post by bentleyjc » Thu Feb 21, 2013 9:26 am
Buddy of mine has an older pontoon and one of the toons has a slow leak. Whats the best way to find the culprit area and fix it somehow (cost effective of course)?
thanks!
2012 Bentley 220SE Cruise - Black
2012 Merc 115 4-Stroke
"Her Caddy"
The_Hellbilly
Re: leaking toon???
#2 Post by The_Hellbilly » Thu Feb 21, 2013 9:37 am
1. Pressurize the toon to approx. 2psi with a small pump or shopvac DO NOT OVER PRESSURIZE, THEY WILL EXPLODE
2. get a squirt bottle with soapy water and start spraying the welds & seams
3. look for bubbles
Take it to a local welder to get it fixed. I don't recommend using any JB weld type products
2005 Voyager 22ft Tritoon
2004 Honda 135hp
Re: leaking toon???
#3 Post by HandymanHerb » Thu Feb 21, 2013 9:45 am
What he said
Re: leaking toon???
#4 Post by badmoonrising » Thu Feb 21, 2013 9:47 am
Yep ^.
bentleyjc
Re: leaking toon???
#5 Post by bentleyjc » Thu Feb 21, 2013 10:04 am
thanks guys - glad you said 2psi because he and I were talking about it earlier today and we were on the right path but we were talking about getting an air compressor and shooting air in it then spray it down... may have shot a lil too much in it doing that
"Her Caddy"
Re: leaking toon???
#6 Post by curtiscapk » Thu Feb 21, 2013 10:57 am
You can use shop vac or lawn blower with some kind of hose.
The_Hellbilly
Re: leaking toon???
#7 Post by The_Hellbilly » Thu Feb 21, 2013 12:33 pm
bentleyjc wrote:thanks guys - glad you said 2psi because he and I were talking about it earlier today and we were on the right path but we were talking about getting an air compressor and shooting air in it then spray it down... may have shot a lil too much in it doing that
someone around here has a video of a pressurized toon exploding. I'll see if I can find it.
2004 Honda 135hp
Nusse
Re: leaking toon???
#8 Post by Nusse » Thu Feb 21, 2013 3:56 pm
I have worked with quality claims at a pneumatic manufacturer.
2 PSI would work (although I'd go for Bar LOL).
There are 3 ways to determine the leaks.
1. Buy leak spray (expensive)
2. Use soap water. Mix hand dishing detergent with water. Use a hand sprayer.
3. This is the best version.....
Dip the whole piece pressurized into a tank or why not the lake and it will show you if there is more then 1 place leaking. By submerging it in water you may not only find that it is leaking in more then 1 place ( saves you going several times to the welder shop) but you can also quantify the leakage by taking a meter glass, fill it with water, turn it upside-down still submerged under the water. Then, move the upside-down meter glass over the leaking bubbles and collect the bubbles. This will give you the cubic-whatever cm/inch a minute the leak is.
Cheers,
jimrs
Re: leaking toon???
#9 Post by jimrs » Fri Feb 22, 2013 8:30 am
Nusse wrote:I have worked with quality claims at a pneumatic manufacturer.
Cheers,
How do you proprose to submerge the toon to find the leak? Who cares about the amount of leakage if it's leaking then it need to be fixed no matter what the quanity of leak is. A leaking toon will eventually sink no matter how small the leak is.
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
slingshot
Re: leaking toon???
#10 Post by slingshot » Fri Feb 22, 2013 2:18 pm
Cheers,
Right, just drive a school bus onto your toon in shallow water then check for leaks. simple really. :biggrin2
2007, 2570 Crest LE II
Yamaha F150
Nusse
Re: leaking toon???
#11 Post by Nusse » Sat Feb 23, 2013 5:32 pm
I should have been more precise.
I dont mean to submerge the whole boat. Just the log. And I don't mean the whole log at one time but side by side. Now that may be tricky if it is still attached to the rest of the boat. But if it is removable then....
Guess the whole idea was to find if there is more the one leakage. To quantify it - well you may have a micro leakage. Not even car tires are completely leak free. You may be surprised what leakage is found and then you will know which leaks to concentrate on fixing.
RonKMiller
Re: leaking toon???
#12 Post by RonKMiller » Sun Feb 24, 2013 10:27 am
Wow, tough crowd here. I guess dogma dies a very slow death.
I'll have to agree that submerging is the BEST, SAFEST and only foolproof way to find leaks. That's exactly what I did with mine when I took ownership of my derelict 1988 Party Hut - and before I started a year long build.
It's EASY to submerge one side at a time by simply piling sandbags on that side, it took 20 (a bit over 2,000 lbs. since I had the large size) to completely submerge mine. Sand is cheap, sandbags are cheap. I hired a couple of teenagers to fill 'em and pile 'em on while I drank beer. Look for the bubbles, then jump in with a dive mask and circle the spot(s) with a black wax dish marking pencil.
If you went the pressurization route Leak-Tek detection spray is dirt cheap and FAR superior to soapy water. It's what professionals use. It will provide LOTS of bubbles on even the smallest leak. A lot of the leaks come from cracked welds where the log attaches to the mounting bracket - they're sometimes almost impossible (especially on the inside of the bracket) to see without a telescoping inspection mirror and bright flashlight.
Nusse
Re: leaking toon???
#13 Post by Nusse » Sun Feb 24, 2013 3:46 pm
Thank you for the support RonKMiller.
RonKMiller
Re: leaking toon???
#14 Post by RonKMiller » Mon Feb 25, 2013 6:57 am
Another quick way to check for problems and one that is very reliable is a simple leak down test with a low pressure test gauge.
Simply pressurize each chamber to 2 or 3 psi and see if the needle moves down. I would give it 15 minutes and keep the log out of the sun while testing on a cool day. You may need to adapt some common plumbing hardware to mount to your bung but it already has a Schraeder valve on one side. If it doesn't hold pressure you now need to do further investigation by either submerging or spraying with leak detector. Make sure the gauge and hardware connection with the valve of your log doesn't leak by spraying it right after you pressurize it, you may need to use a wrap of Teflon tape.
Here's one from http://www.pascospecialty.com/products.php that should work perfectly. The little ball valve is especially nice to have since you can meter the EXACT amount of air flowing into the log instead of doing it in spurts.
low pressure test gauge.jpg (49.31 KiB) Viewed 44550 times
I've got the 15 psi version which is also acceptable since it reads in 1/10 psi.
Either one should be around $20.00.
Nusse
Re: leaking toon???
#15 Post by Nusse » Mon Feb 25, 2013 7:57 am
[quote="RonKMiller"]Another quick way to check for problems and one that is very reliable is a simple leak down test with a low pressure test gauge.
quote]
It is a good way, just be carefull with the Schaeder Bellows valve.
1. All valve leak (more or less) even a new valve has a allowed leakage (specification) in order to pass the EOL-test at the manufacturer. The small leak of the valve may show you more leak then you actually have over the logs.
2. Schrader quality - well I am not going to go there.
3. Considering the very large volume of the log. I would perhaps even use more time to see if there is a pressure drop. A few hours at least.
Cheers,
