I added a Blue Sea Add-A-Battery to my boat.
This is how I did it.
The box is a Carlon (Model E989NL) 8†X 8†X 4†Junction Box, from Lowes
The strain relief's are Halex ½†(Model 27693) and ¾†(Model 27697) ACC Non-Metallic Strain Relief Cord Connectors from Home Depot
Throw in two Blue Sea ANL fuse holders with 100 Amp ANL fuses, and a 4-position terminal block with cover for all the ground wires.
If I were going to do it again, I would probably use the Carlon 12" X 12" X 6" box.
- Add A Battery Schematic.jpg (101.71 KiB) Viewed 21477 times
- Photo06150729_50.jpg (111.86 KiB) Viewed 21508 times
- Photo06150801_1_50.jpg (119.87 KiB) Viewed 21502 times
- Photo06150729_1_50.jpg (101.05 KiB) Viewed 21498 times
Re: I added a Blue Sea Add-A-Battery to my boat.
Very well done and excellent post with info
I live in my own mind
Ain't nothin but a good time
No rain just the sunshine
Out here in my own mind
-Lyle Lovett "In My Own Mind"
2011 Princecraft 21 full camper top
90 Merc efi 4 stroke
+1 Very clean install!Mr Geets wrote:Very well done and excellent post with info
2006 Bennington 2575 RFi pontoon with a 2006 Yamaha F150TLR
monksblood
That is impressive. Nicely done, thanks for the idea
21 ft Sweetwater with a 90 E-tec, looking a bit beat up
Why did they use a fuse on the ground ???
Very neat intall. Congrats.
I love my ACR and it also has a fuse on the ground.
Not sure why tho. I just hooked it up according to SOP and it has worked for years.
Bob, did you run a forward 'controller/indicator'?
Nice job!
you may want to make a copy of the wiring diagram and seal it up in the box, or laminate a copy and store it in a batt box for a quick future reference.
here, pull my finger
2011 Godfrey Sweetwater
Yamaha F70
Yamaha F70
Damn! I just hate it when a DIY project turns out looking like a professional install!!
If it were me there would have been extra pieces laying around and the mount would NOT have been plum and square.
Great job!!
Great job!!
F225 Yamaha
F225 Yamaha
Great write up. I will definitely be using this thread for info later this spring when i add my 2nd battery
Thanks for sharing!
Thanks for sharing!
Riviera cruiser
35hp merc
Towed with an '87 Jeep Grand Wagoneer
35hp merc
Ok after waking up I see that fused ground is only to relay, not to the loadsHandymanHerb wrote:Why did they use a fuse on the ground ???
- TonyTwoToons
Bob (or other people smarter than me),
Great post. It should be stickied!
I'm going to install my mini add-a-battery shortly. I'm going to use a larger junction box though (learning from others' experience). The layout will be nearly identical but I want to mount the box directly to the fence panel. I'll put a few rubber washers between the panel and the box for air flow. Is mounting it to the fence panel a good idea? Should I be worried about something I'm not thinking of or don't know about?
Sorry for bringing an old thread back from the dead.
Cheers,
Tony
Cheers,
Tony
Glad to be here, proud to serve.
2000 20' Suncruiser Trinidad 204 w/ 1999 70HP Evinrude 4 Stroke
Cruisin' The Red River in Shreveport/Bossier City, Louisiana
- Mosnowman
Looks great! I added one last year...check that...my Marine guy added it (I have no talent what so ever)....and love it!
Impressive clean install....I'm jealous of your ability....enjoy!
BUSY LIVING...
Columbia Mo BZLIVN
Columbia Mo BZLIVN
I, too, followed Bob's lead when I redid our pontoon last summer. I put my box under the rear seat:
- 11.jpg (72.47 KiB) Viewed 19771 times
__________________________
1999 Lowe Suncruiser Trinidad 220
90 HP Evinrude 2 stroke
What ever happened to 'ol Bob ? Haven't seen him post in a long time.
2019 Veranda 22 RFL 250SHO
Yea he hasn't post since Aug 20th, hope he alright, he's our favorite lib
