Had to drain the toons
Shopguy
#1 Post by Shopguy » Tue Feb 26, 2013 8:48 am
Yep, pulled the toon out from the shop to do some cleanin and my boy said he heard water sloshing in the port side. Guess it was only a matter of time.
I took an 1/8" bit and drilled all three logs about 3/8" from the bottom. My plan is to use 1/4" nut zerks (since I have the tools) with sealer and then use a bolt with a nylon washer. Check it periodically to see how much water we're taking on.
A nut zerk works like a rivet. We use them in places where you can't weld a nut on the back side of metal. For a 1/4" bolt, you oversize the hole just enough to get the nut zerk in and insert the nut using the tool to compress the nut from the backside (like a rivet). Gotta use sealer for under water and sinch it down tight. Quick and easy.
Should work for now until I get my TIG wired in the shop so I can weld in some 1/2" bungs with plastic plugs later.
Shopguy
Strakes and skins
Re: Had to drain the toons
#2 Post by lakerunner » Tue Feb 26, 2013 10:43 am
I have had a small leak in one nose cone for years and I use a #10 stainless screw with a rubber washer. It works great.
rlcrews
#3 Post by rlcrews » Tue Feb 26, 2013 11:04 am
glad you made this post with some of the comments you made . this leads me to a question i wanted to make my own post with which is why do they use a plastic instead of galvanized plug in the toons ?
#4 Post by lakerunner » Tue Feb 26, 2013 11:23 am
A galvanized plug will cause corrosion between the two metals. You must use Aluminum, plastic or Stainless Steel.
Shopguy
#5 Post by Shopguy » Tue Feb 26, 2013 11:51 am
Yep, can't use two diff metals together in water. I always use antisieze regardless, just keeps whatever it is from locking up, especially if you plan on taking it back apart.
also thought about putting a screw in it. I did my dad's toon that way and works well also. If I didn't have the zerk kit I'd do the same. Figured I'd fancy it up a little.
In a jam I guess you could use those plastic drywall anchors too. Pop one in and put a screw in it.
Shopguy
Strakes and skins
