keosports
#1
Post
by keosports » Sat Apr 06, 2013 8:19 pm
21' sunbird tritoon deckboat E-Tec 150
25' fiberglass deck unknown mnf. Yam 70
20' rebuilt sweetwater Johnson 115
21' monark parts boat Evinrude 60
16' tango jet boat Merc 175
12' inflatable catamaran Yam 9.9
10' hobie sport mirage 1 Me-power
keosports
#2
Post
by keosports » Sat Apr 06, 2013 8:21 pm
what do you guys think would be the best option, goal is trying to get a top speed of 40mph and be able to cruise around 25-30mph
keosports
#3
Post
by keosports » Sat Apr 06, 2013 8:25 pm
#4
Post
by Bamaman » Sun Apr 07, 2013 10:41 am
The pontoon would probably work best with a 20" motor. You will never get it to 40 mph without lifting strakes, and strakes are highly engineered items. What works on one boat won't necessarily work well on another.
The fiberglass boat looks like a long term project.
I'm sorry that I don't have any suggestions for you.
#5
Post
by margaritaman » Sun Apr 07, 2013 2:46 pm
Looking at the second photo down, is that a fiberglass deck fastened to the pontoons? It does not look like a lot of bolts holding it down.
keosports
#6
Post
by keosports » Sun Apr 07, 2013 5:20 pm
yes the pontoons are bolted directly to the molded fiberglass deck.
2 mechanics and a rep from waterglide both told me I need 25" motors if I planned on doing anything that would raise the boats up out of the water, (glide, strakes, center tube) waterglide claims after installing the boat sits 5" higher in the water
Mrtoler
#7
Post
by Mrtoler » Mon Apr 08, 2013 3:45 pm
I would invest in a center tube and strakes before I did a water glide. I've never had either but I do a TON of research since I'm wanting the same kinda peformance outta my boat! My plan of attack is center tube with strakes rated for BIG power, run that with my current motor until I can buy a new verado
2006 dodge ram quad cab
Crosby Texas
keosports
#8
Post
by keosports » Tue Apr 09, 2013 1:30 pm
a full center tube is not an option since one of the boats has a fiberglass molded transom and the sweetwater has a 103" engine pod welded onto the cross members
