Speedo quit, where is the intake?
jshumphries
#1 Post by jshumphries » Fri Apr 26, 2013 7:19 pm
Called the svc dept and they said the intake was on the skeg, just above the bullet. It's a new Merc 150 4stroke. Any suggestions? Tried a small drill bit on the only hole I could find in front of the cooling intake holes....Help!
Jeff and Elizabeth
'12 Harris Cruiser CX220 150 merc
39mph gps 6 people
Cumming, Ga
Lake Sydney Lanier
Re: Speedo quit, where is the intake?
#2 Post by HandymanHerb » Fri Apr 26, 2013 8:29 pm
So your speed pick up is part of your engine, I had a seprate pick up on my right pontoon, I'm not putting it back with the rebuild, GPS will tell me the speed if I care
BoatCop
#3 Post by BoatCop » Fri Apr 26, 2013 9:11 pm
There's a little hole at the front (sharp end) of the lower unit. It attaches to a rubber tube (called a pitot) that goes up to your speedo. The speedo reads air pressure as the water pushes into the hole. The faster you go, the more pressure, the faster your speedo reads.
If the speedo doesn't work, there's a few things that could go wrong.
1. The hole is clogged
2. The tube came off from the connection to the power head from the lower unit
3. The tube is split or cut somewhere between the engine and the speedo
4. The tube came off the back of the speedo.
#4 is pretty common, and usually the easiest to check. It's also the easiest way to troubleshoot the other problems.
Pull the tube off the back of the speedo and blow (or use LOW PRESSURE - 5 PSI or less) into the tube. Have someone check the hole on the lower unit to see if air is coming out, or use soapy water and look for bubbles.
Sometimes that's all you need to clear the line if it's clogged with sand or silt. If there's no air coming out of the hole, then it's probably #s 2 or 3.
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
bassn386
#4 Post by bassn386 » Sat Apr 27, 2013 7:37 am
I've got an Optimax on my bass boat and I quit worrying about the speedo a long time ago. I think it takes about a 1/32nd bit to clear out the hole and here at Lake of the Ozarks there's a lot of crap in the water in the spring. I just use the tach.
F225 Yamaha
RonKMiller
#5 Post by RonKMiller » Sat Apr 27, 2013 7:42 am
If you have a smart phone there are many apps that can tell you your speed. The one I used is much more accurate than any pitot based speedo. It's called "Ulysse Speedometer".
bassn386
#6 Post by bassn386 » Sat Apr 27, 2013 7:56 am
When people ask if I have a smart phone, I tell them it is mildly retarded.
F225 Yamaha
#7 Post by curtiscapk » Sat Apr 27, 2013 1:45 pm
RonKMiller wrote:If you have a smart phone there are many apps that can tell you your speed. The one I used is much more accurate than any pitot based speedo. It's called "Ulysse Speedometer".
yep it is awesome!!!
jshumphries
#8 Post by jshumphries » Sat Apr 27, 2013 7:14 pm
Many thanks for the tips and directions. It was so crammed with dead wood that I had to start with a 1/16 th bit and move up from there. Bit I had yesterday was too big to fit the hole, which was so small I just thought it was a knick in the skeg. More to ease my mind that the new boat wasn't broken. Will use the Fishfinder for speed from now on. Thanks also for the smart phone app. Very cool!
Jeff and Elizabeth
39mph gps 6 people
Cumming, Ga
Lake Sydney Lanier
#9 Post by curtiscapk » Sat Apr 27, 2013 9:59 pm
no prob I use it in the car too, to keep an I on the admiral's speed....
jafo9
#10 Post by jafo9 » Sun Apr 28, 2013 10:05 am
most folks will agree that pitot speedos are pretty unreliable. even when mine is clean an functioning on my honda (same location as yours), it pretty inaccurate until i get to around 10-15mph. the only reason i ever clean it out is my ocd kicks in when i see a gauge not working. otherwise i use the gps i have mounted to the helm for speed.
2002 MasterCraft X30
2007 Yamaha FX HO Cruiser
2005 Kawasaki SXR800
2004 Yamaha SuperJet
1989 Kawasaki 650sx
Lewis Smith Lake, Alabama
BobG
#11 Post by BobG » Mon Apr 29, 2013 8:05 am
I'm really glad I don't have a pitot speedo. The GPS is all I have.
#12 Post by HandymanHerb » Mon Apr 29, 2013 8:27 am
Got the speedo app loaded and used it running around town working, the HUD works good, just lay it on your dash and read it on the windshield
