How many of you use stern tie downs?
MPosey519
Re: How many of you use stern tie downs?
#16 Post by MPosey519 » Mon May 06, 2013 7:13 am
Yep, I tie down bow and stern. ratchet straps as well. one on each log in the stern, and one strap going log to log under the trailer arm on the bow.
Michael
Rough River Lake, Kentucky
50 HP 2003 2-stroke Mercury
stickman
#17 Post by stickman » Mon May 06, 2013 7:59 am
I always strap mine down (see pic). Notice on the starboard side that my strap actually lays right on the mount.
I have never seen one come one off the trailer first hand, but when someone in the future asks if they have ever had an issue, I don't want to be the guy they are referring to when they say, "No, but I once saw a guy with a pontoon that...".
Note, the yellow line in the middle of the picture is because I had a temporary fly covering the boat before I got my barn built, and I needed to keep the fly from blowing away.
220hp 4.3L mpi Merc
Beautiful southwestern Ohio
#18 Post by lakerunner » Mon May 06, 2013 5:29 pm
Here is how I added 2 eye bolts to tie down stern
#19 Post by curtiscapk » Mon May 06, 2013 7:30 pm
Fantastic idea Loyd!!!!
#20 Post by lakerunner » Mon May 06, 2013 9:04 pm
How many have the warning above the transducer bracket?
It says Caution Moderate Injury could occur trying to us it as a step.
GXPWeasel
#21 Post by GXPWeasel » Tue May 07, 2013 6:07 am
When mine's on the trailer, it's always tied down. 2 rear straps, the regular winch strap, and a backup / safety strap to the winch strap. I don't want to take any chances to save 2-3 minutes.
"Nauti Weasel"
2005 Beachcomber Islander 26
justrfb
#22 Post by justrfb » Tue May 07, 2013 6:25 am
+1... ALWAYS tied down...
Sincerely,
Rich
Rich and Annemarie Bias
2007 Merc 75 4 Stroke
2006 Honda Pilot
VaGent
#23 Post by VaGent » Tue May 07, 2013 8:25 am
I use a "safety CHAIN" on my bow as well as the winch strap. Two ratchet straps on the stern. One for each log. I installed a 1/4"X4"X48" piece of 6061T aluminum to the cross members in the bow to attach the bow "eye" to. This allows me to pull against 4 cross members instead of just one in the front. I've seen several of the bow eyes pull out & or bend the first cross members on several boats. I looked that newer boats & many of them have the bow eye installed this way. It might be an "over kill" but it sure beats having the bow eye pull out.
1993 24' Voyager 2006 E-TECH 90-Fishing Barge
1984 24' JC 2011 E-TECH 90-Family Cruiser
2010 Silverado LT Quad Cab 5.3 Vortex
redbeard
#24 Post by redbeard » Tue May 07, 2013 9:06 am
1+ on the always 4 points, 3 straps 1 chain
#25 Post by Bryden24shp » Tue May 07, 2013 11:52 am
Alot of info and pics of how I strapped my old Manitou down for the long haul, here.... viewtopic.php?f=2&t=13728&start=0&hilit=towing
Pretty much the same with the Premier, too.
Might help!
Drago
#26 Post by Drago » Wed May 08, 2013 9:36 am
When I did this to my trailer bunks, I decided the short trip to the lake ramp was too hilly to not tie down the rear. This stuff is just to damn slippery! I do it all the time now, not just on long trips where I tie four corners.
I added stainless steel 3/8" eye bolts to the ends of four conveniently placed channel aluminum frame members. I tie to these eye bolts and to the trailer frame.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
oldcoot
#27 Post by oldcoot » Thu May 09, 2013 11:07 am
We always have ours strapped down....last year on St. Paddy's day, a drunk driver going the same direction, ran into the boat while we were pulling it home...at the time I had a Blazer....he had a Yukon and as the Blazer was starting to turn towards his truck, I could see him puking out his window...he had turned into the boat and if I had not had tie downs on the back...it would've come off the trailer, flipped both of us and just a disaster.Luckily I whipped the wheel to the right and was able to get under control and chase him through a busy casino lot and get the plate....he recieved 7 citations...and his insurance cancelled.
BUT...my wonderful wife and I are ok and able to continue 'toonin'! :thumbsup
Jim & Jill
East Peoria, Il.
Illinois River Tooners
90hp Tracker Mercury
"the Jillie Marie"
#28 Post by curtiscapk » Fri May 10, 2013 8:17 am
this is a good deal if you want a cheap way to protect your toon.
http://www.basspro.com/Transom-TuneUp-K ... 302271053/
and free shipping.
SoCalAngler
#29 Post by SoCalAngler » Sat May 11, 2013 12:27 pm
what are your thoughts on drilling two 1/2" holes on center cross member about 2 feet in from both right and left trailer lights and mounting eye bolts. I can then attach a strap to top of pontoon log eye-ring and other end of strap to an eye bolt mounted to the 1/2" holes. Straps would angle towards center of trailer and would avoid the transducer mounting bracket.
I really do not like drilling holes in my trailer, especially 1/2"
I just want a simple, safe way to tie down my transom without ruining my transducer bracket.
Thoughts?
2011 Keystone Outback 250RS
chill'nthemost
#30 Post by chill'nthemost » Sat May 11, 2013 9:52 pm
oldcoot wrote:We always have ours strapped down....last year on St. Paddy's day, a drunk driver going the same direction, ran into the boat while we were pulling it home...at the time I had a Blazer....he had a Yukon and as the Blazer was starting to turn towards his truck, I could see him puking out his window...he had turned into the boat and if I had not had tie downs on the back...it would've come off the trailer, flipped both of us and just a disaster.Luckily I whipped the wheel to the right and was able to get under control and chase him through a busy casino lot and get the plate....he recieved 7 citations...and his insurance cancelled.
I'd have a few other comments if this wasn't in the general discussion forum, but wow....Could of been a way different out come for both of you. I had a moron run me off the road on the way back from the lake a few years back. He kept running others off the road in front of us. Pissed me off so much I went miles past my house to chase him down (pulling a 25ft toon) to get his plate number. I'll never know if they caught the SOB, I can only hope.
