Poll on your Tire Pressure ??
Capt Sully
#1 Post by Capt Sully » Wed May 08, 2013 12:08 pm
Just wanted to start a poll on what tire pressure you set your tires on to pull your pontoon ??? Also what size tires you have, 13" 14" 15" etc.
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
redbeard
Re: Poll on your Tire Pressure ??
#2 Post by redbeard » Wed May 08, 2013 12:25 pm
I have 13" at 50#, I have been around trailers all my life [55 years] and we have always used max pressure, every time that I have blown out a tire is because of low pressure only three times. My trailers are all over the place so now I carry a compressor with me to air up my tires.
#3 Post by Bryden24shp » Wed May 08, 2013 12:52 pm
My max capacity is 55 lbs, thats where they are at! Lower the pressure, the more wear on sidewalls from flexing plus heat build up. I have always had all my tires at the manufacturers max. Only 1 flat in 35 years. Always get good wear patterns. Now that I jinxed myself, again :hammer :hammer Thats twice today!!!
Drago
#4 Post by Drago » Wed May 08, 2013 2:58 pm
We have the same tires as Redbeard...
13" load range c ST185/80R13 max load 1480 lbs 50psi max inflation.
You have to pay attention when on the road since pressure can change due to many variables.
A good read is at
http://www.tirerack.com/tires/tiretech/ ... ?techid=73
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
DRock
#5 Post by DRock » Wed May 08, 2013 3:09 pm
I always keep my trailer tires at the max pressure as well. When i mount trailer tires at the shop for customers i always put them at the max pressure as well.
Cars/trucks-I go off of the door sticker with a few exceptions.
MH Hawker
#6 Post by MH Hawker » Wed May 08, 2013 3:33 pm
i have the small ones 20.5 x 8.0 x 10 in a E load rating at 90 psi.
crspang
#7 Post by crspang » Wed May 08, 2013 4:48 pm
I keep mine at max psi also. 90psi.
Silver Eagle
#8 Post by Silver Eagle » Wed May 08, 2013 7:03 pm
I keep my 10 inch tires at 50 #'s.
#9 Post by lakerunner » Wed May 08, 2013 7:04 pm
redbeard wrote:I have 13" at 50#, I have been around trailers all my life [55 years] and we have always used max pressure, every time that I have blown out a tire is because of low pressure only three times. My trailers are all over the place so now I carry a compressor with me to air up my tires.
same here
playcat
#10 Post by playcat » Wed May 08, 2013 7:16 pm
MH Hawker wrote:i have the small ones 20.5 x 8.0 x 10 in a E load rating at 90 psi.
same here on all three axles
playcat
JC 266 TriToon
Kerr Reservoir, VA
GXPWeasel
#11 Post by GXPWeasel » Wed May 08, 2013 7:46 pm
I keep all tires on all vehicles and trailers at max psi. Our trailer tires are kept at 50 psi.
"Nauti Weasel"
2005 Beachcomber Islander 26
justrfb
#12 Post by justrfb » Thu May 09, 2013 3:40 am
Hello All.
I have 13" tires. Max pressure is 65#! I keep it at about 63#. I just got the trailer recently and looked at the tires more than once to see if I was seeing the number right. Now I am a little worried because no one else has 65# max pressure. I will check when it stops raining!!... :donno I keep my cars and SUV tires at or near max according to sticker on door jam.
Sincerely,
Rich
Rich and Annemarie Bias
2007 Merc 75 4 Stroke
2006 Honda Pilot
ROBBSRACINGENGINES
#13 Post by ROBBSRACINGENGINES » Thu May 09, 2013 6:41 am
I run mine at the max rating of 90 psi also. 20.5X8-10 Loadstar E rated tires.
kryptonite
#14 Post by kryptonite » Thu May 09, 2013 6:49 am
13" at 50PSI
OK Toon
#15 Post by OK Toon » Thu May 09, 2013 7:19 am
Crap I better check my tires. I have the smaller tires but I don't think I'm anywhere near the 90psi Max. If I recall, I only set them to around 50-55 (I just couldn't bring myself to going any higher than that). This is our first boat and I've never had any trailer before with these little fat tires so I'm just not used to having anything that can have that high of a Max rating.
